Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Need a sheet that shows the assembly of a xerox xd100 fuser
I need something that shows how a fuser is assembled for a xerox xd100.It was taken apart and now not sure how to put back together.
Can someone help?
mejenkins6@bellsouth.net
    Guru:
  • 1,342 Answers
WorkCentre 7345 Fuser Assembly replace soon showing. please how i reset this
Replace the fuser assembly.
The fuser melts the toner ink onto the paper.
As such, it's a vital part of the printing process.
Mar 25, 2015 | Xerox WorkCentre 7328 7335 7345 7346...
Does the Corotron Assembly Kit for the XD100 contain the Corotron Wire as part of the assembly kit?
Yes it does:
PL 7.3 TRANSFER/DETACK
COROTRON ASSEMBLY
Item Part Description
1 - DETACK COROTRON
2 - GUIDE
3 - INSULATOR
4 - FRONT GUIDE
5 - SCREW (3X6)
6 - CONTACT COVER (R)
7 - TENSION SPRING
8 600K15950 TRANSFER COROTRON WIRE
9 - SPRING BRACKET
10 - TRANSFER COROTRON SPRING
11 - BC SPRING
12 - GROUNDING SPRING
13 - CONTACT COVER (F)
14 - COROTRON HOUSING
15 - PLATE
16 - GROUNDING PLATE
17 19N415 TRANSFER/DETACK COROTRON
ASSEMBLY (REP 9.2)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox XD100 paper jamming every time.
The fuser is the problem. Most likely the fuser will need to be rebuilt or replaced.
Google a business called The Parts Drop. they have either the parts or the unit.
You may just have to take the fuser out and remove a badly jammed piece of paper in that module.
Shut the machine off for a half an hour. Remove the back cover. You will then see on the left side a black plastic bracket with 3 plugs on it. Disconnect those 3 plugs. Then open the right side door and toward the top is the fuser. It has yellow caution HOT labels on it. There are 2 silver phillips screws holding it in. Remove the screws and then remove the fuser unit and see if there is a paper in there. There are 2 screws that you can remove and the fuser will kind of fold open to inspect for bent fingers or one out of place.
Mar 30, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
We have a workcenter pro 45. The new fuser module is on order, but the fuser model went out today. Is there a way to override the error until the new module arrives?
What error? H4? If so then you can get the reset procedure by searching my tip for this under "Sharp AL series H4"
Your Xerox XD100 is made by Sharp
Mar 19, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
I have a paper jam on the right side of my Xerox WorkCentre xd100. I can't find my User's Guide, and don't know how to release the paper jam.
If the paper is in the fuser area, the fuser needs to be taken out.
I have heard and seen some customers take out the fuser. It has two wood screws to be removed and the plug on the side.
Extra care needs to be taken when doing this task.
Unplug the machine.
remove the two screws and unplug the fuser plug.
Gentley pull out the fuser and you can see the paper in the fuser.
There are small stripper fingers down there, be very careful when taking partial pieces out, be very patient, and extra careful.
This roller does not turn very easy if you need to rotate it.
To reassemble, DO NOT OVER TIGHTEN THESE TWO SCREWS!!!"
Just tighten snugger than snug tight. Which means a loose tight. The mounting walls can break very easy.
If the problem jam is below by the tray, try to manage to push a card stock from below to get out the paper.
Let me know if this works.
Good luck.
Sep 09, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
XEROX WORKCENTER XD100 NOISE
Most likely the fuser gear is worn. The noise is prominant in the right side toward the back I am assuming.
You can replace the heat roll drive gear itself, but honestly I would recommend replacing the entire fuser assembly. It is probably very very tight and would wear another gear out quickly.
You want to get that replaced before the drive gear on the main motor assembly wears out. It would not rewuire replacing that entire main drive assembly, But it is a real difficult part to replace.
Go onto google and do a search for The Parts Drop. It will be the first item to come up. CLick it on and call and talk to Britt.
He will have what you need for a reasonable price.
if you go that route and need instructions to replace that part. let me know. Its not very difficult.
Jul 16, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox XD125F
What you can try is just replacing the fuser drive gear and the bushings on the heat roller.
That small tube your relating to is the heat roller. The plastic like busings are really tight not allowing it to move freely.
Not the easiest fuser to rebuild to be honest. You will also want some high temperature lubricant to use on those bushings and also on the pressure roll shaft to make that roller run smoother.
Clean it well and be sure it is running free.
You need to look at the heat roll and presure roller carefully to check for wear and grooves. If they are worn, you will be better off replacing the fuser then trying to rebuild it.
I will provide you the link to an excellent parts source, click on parts then the scroll down tot the XD125, They have about everything you want for that fuser.
If you call ask for Britt..
https://www.partsdrop.com/store/
Apr 08, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
119 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
