Question about Bosch Axxis WTA 3510 Electric Dryer
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40 minutes in the dryer but when it is all dry it is warm. Is part of the heating element broken? because it use to be cold only until i reset the thermostat on the heating element. But it is still not hot as i would like it to be. Also when on auto dry it gets cold after the damp dry light turns on. Is my heater element the cause of all this?
  • Bosch Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 22, 2010
The heating element works but no hot air blows so it takes 2 hours or more to dry a load of clothes.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 06, 2011 | Frigidaire Electric Dryer
Dryer runs, rotates, and air blows but does not blow hot air, therefore cloths will not dry.
heatman101
Apr 13, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Dryer is turning on but does not get hot and is not drying the clothes.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Bosch Nexxt 500 Dryer
Hi. My LG Tromm Dryer DLG3788 warms at times, heats hot others and sometimes won't heat at all. Either way the clothes either don't dry at all or take hours. Any suggestions? Thanks.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Dryers
Not drying with heat
heatman101
Jul 27, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
My dryer is not getting hot or even warm
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Jun 10, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
My Bosch Axxis electric dryer Mod. # WTA3510UC 82/IV takes a few cycles to dry if it dries completely. The laundry doesn't seem to get warm no matter the setting. Have checked exhaust, cleared lint from...
i would check the actual electrical connections, to both the unit, and the downline connections to that actual element itself, its unusual for an elemnt to only go a lilttle bit... it works or it doesn't...
since you seemed to be very knowlegable, ohm
out the element as well as your plug and outlet
ther emay be a loose connection somewhere
Oct 13, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Maytag MDE8600AYW takes way too long drying clthes
either your house vent is plugged, or the vent in the dryer by the blower is plugged. when the vent is plugged, even partially, the moisture is not leaving the dryer. It will take a long time to dry, and the top of the dryer will get hot when the vent is plugged. Clean the house vent and check down below the lint trap by the blower, then it will dry fine again.
Oct 09, 2009 | Maytag MDE8600AY Electric Dryer
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
254 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
