Question about Texas Instruments TI-83 Plus Calculator
Find the rate of change of the volume of a cylinder when its radius is 6 feet if its height is always (3/2) times its radius and its radius is increasing at the rate of 2 feet per minute.
  • Texas Instru... Master
  • 8,016 Answers
I have no idea about your knowledge of calculus. But the solution requires calculus (I am in no mood to introduce a Delta V and Delta t and let Delta t approach zero.)
Posted on Aug 24, 2010
What is the volume in liters of a water tank with ....... radius 2 feet 6 inches height 5 feet 2 inches
Assuming you are correct that the radius is 2' 6" and not the diameter.
Convert the inches to centimetres
1" = 2.54 Cms
Radius = 2' 6" = 30" X 2.54 = 76.2 Cms
Height = 5' 2" = 62" X 2.54 = 157.48 Cms
Volume of cylinder = Pi x radius squared x height
3.142 x 76.2 x 76.2 x 157.48 = 2,873,038.9 cc
Divide by 1000 to find how many litres (interest note 1000cc car engine is 1 litre)
2,873,039 cc / 1000 = 2,873 litres
Nov 08, 2017 | The Office Equipment & Supplies
How do measure the cubic feet into a cylinder
The formula is V = Pi * R^2 * H where
R: radius
H: height
V: volume
So you need the radius and height in feet, and plug them into this formula. Or you can enter what you know, in feet, to this calculator, and it will give the unknown
http://www.onlineconversion.com/object_volume_cylinder_tank.htm
Mar 19, 2016 | Office Equipment & Supplies
How many cubic yards would it take to fill in. 20' x 2' diameter
Hi Paula:
A mathematical logic question.
You need to get all of the measurements in the same units.
- A cubic yard is 1 yard x 1 yard x 1 yard
- equals 3 ft x 3 ft x 3 ft
- equals 27 cubic feet,
so once you have the volume of the pipe in cubic feet, you divide by 27 to get the volume in cubic yards.
- Volume of a cylinder (the pipe) is the cross sectional area X length.
- Area equals Pi x r squared.
- equals 22/7 x 1 x 1
equals 3.14#####
times length (20)
equals 62.857### cubic feet volume
divide by 27 cubic feet
equals 2.328### cubic yards.
- The answer is always the easy part.
- what is important is knowing exactly what the question is, and
- determing what calculations are needed to get the answer.
Wasn't that better than if I'd just said 2 1/3 cubic yards?
Cheers
Jan 05, 2016 | Office Equipment & Supplies
Find the volume of a cylinder the radius is 8cm the height is 6cm what is the volume
Volume of right cylinder is
V=(Area of base)*height.
If cylinder is circular Area of base =PI*radius^2=Pi*r^2
Volume is V=Pi*(8^2)*6 cm^2
Finish the calculation.
Jun 28, 2014 | Office Equipment & Supplies
Find the volume of a cylinder with the radius 8cm and the height 6cm. Use 3,14 for round answer to the nearest tenth
Jun 28, 2014 | Casio MS-80TE Calculator
Volume of a cylinder formula
Volume of a right circular cylinder of radius r and height h is
V=PI*(r^2)*h
Figure out which is the radius and which is the height, then plug in the formula above. Result is in cm^3
Jun 26, 2014 | Office Equipment & Supplies
What is the Formula for calculating volume of a cylinder
volume is calculated by finding the area multiplied by the length or height . That is Pi X radius squared X length
example --tube 6"dia 12"long what is the volume?
Example 3.1417 X radius 3" Squared =3.1417X9sq " = 28.2740sq" X length 12" =338.688 cubic"
If you want the volume of an engine cylinder , it is the same formula and the length is the stroke of the piston ( distance from TDC to BDC )
May 20, 2014 | Office Equipment & Supplies
What size cone is needed to hold 150 gallons
You need a cone with a volume of 150 gallons.
The volume of a right circular cone is given by the formula
V_cone=(Area of base *height)/3
Since cone is circular , its base is a disk with a certain radius r. The formula becomes PI*(r^2)*h/3
As you see there are two variables, the radius and the height. There is an infinite number of combinations (radius, height) that will give you a total volume of 150 gallons. You can choose the radius (r) and solve for h, or you can choose the height then solve for the radius.
I suggest you convert gallons to cubic feet or to cubic meters then put
V=Pi*(r^2)*h/3 where V is the value of volume after conversion.
If you choose the radius, then to isolate h, h=(3*V)/(Pi*r^2)
If you choose the height, then to solve for r
r^2=(3V)/(Pi*h)
and r=square root of (3V/(Pi*h))
Now, it is your turn to carry out the rest of the calculation.
It will consist of the value of the radius, and the value of the height.
If the cone is not right circular, the situation becomes more complicated.
Sep 16, 2013 | Office Equipment & Supplies
If a lead pipe 1/4in.thick has an inner diameter of 1/2in.,find the number of cubic inches of lead in a pipe 10ft.long
A pipe can be seen as two cylinders, one of "air" sitting inside the other, in this case lead.
To get the volume of a pipe you thus subtract the volume of the "air" cylinder from that of the lead cylinder.
Volume of a cylinder = area of circular cross section (or pi times square of the radius) times the height (or length) => ? * r2 * h
Volume of a pipe = Volume of cylinder 1 (outer diameter) - volume of cylinder 2 (inner diameter).
In this case; Volume of outer cylinder => inner diameter 1/2" (0.5") + pipe thickness 1/4" (0.25") = 3/4" (0.75") divided by 2 to get radius = 0.375".
3.14 (?) * 0.375 * 0.375 * 120(10 feet) = 53.01438 in3
Volume of inner cylinder => inner diameter 1/2" (0.5") divided by 2 to get radius = 0.25".
3.14 (?) * 0.25 * 0.25 * 120(10 feet) = 23.56194 in3
Volume of lead in this pipe = 53.01438 - 23.56194 = 29.45244 in3
Hope this helps ;)
Jan 27, 2011 | Computers & Internet
Texas Instruments TI-83 Plus Calculator Logo
519 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
