Question about Maytag MSD2656G Side by Side Refrigerator
MSD2655HEQ Everything seems to be running but no cool air. The coils are clean. The compressor seems to be running- it feels hot. The fans are on. Only about 5 years old.
  • 122 Answers
Maytag has 5 year warranty on sealed system, sound like you may have a restriction
Posted on Aug 22, 2010
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Cooler not getting cold
By not hearing anything but the fans I would have to say the compressor is not running. Pull the cover off so you can access the condenser area where the coil and compressor are located. Check the coil and ad make sure it is clean. Then feel the compressor and find out if the compressor is hot. If it is hot and the coil is dirty/dusty I would say it was going off on high head pressure/temperature. Clean the coil and let the unit sit off for a while and then try running it. If it is cool then it may have an issue with the refrigerant or other things like maybe start componenets.
Mar 27, 2014 | True GDM-12 Refrigerator Commercial
Hot spots on outside of Amana fridge. sxd22s2w model
if it feels like it's running hot check the coil to see if it needs to be cleaned,remove the bottom kick plate and look at the coil,the coil should be cleaned once every 6 to 12 months,also pull the fridge out,remove the back bottom panel,make sure the condenser fan is blowing and vac out any lint near the fan and compressor,also check the cover that you removed and clean that too.you might want to unplug the fridge while you clean back there so you don't hit the fan blade,wait 5 minutes before you plug it back in so the compressor can reset itself.there are gas lines that run through the frame of the machine,if the coil is jammed with dust and lint the machine runs hotter,this is how it cools off through the condenser coil and the fan blows the air around to help cool it down,if it runs hot then the freon will run hot and you could feel it on the frame and in the strip where the doors close together.you can buy a brush that you can push into the holes of the coil to pull the dust out or if you have a shop vac you can vac out as much as you can and then put it on blow and blow the dust out of the coil,just hit it with short bursts or the dust will blow everywhere.
May 22, 2011 | Amana Refrigerators
Turn thermostat on, cooling fans kick in, i can feel compressor with my hand moving but no cooling inside freezer or fridg
Hi, you say the fan in the freezer kicks on? You also have a fan located by your compressor and coil which is the condenser fan motor and condenser coil. This fan must also be running when the compressor is on.Make sure that the coil down below is clean on the front of it as it draws air across this coil to keep the internal head pressures down. Check all of these things. The small copper line coming off the compressor, discharge line should be almost hot. The larger of the lines is the suction line and will be very cool, almost condensating . If not, you may have developed a small freon leak which will cause these problems. Make sure that everything I said is working and clean, and if the small motor in the rear bottom is not running, you can get a new one at a appliance parts house and 2 wires will replace it. Do all of this and keep me posted.
Shastalaker7
Jun 15, 2010 | Refrigerators
Will not cool. Fan runs, have cleaned coil.
The compressor may not be starting. Put your forehead against the nmachine when youturn it on or plug it in, You will feel the vibration of the pump. If it is not coming on, you may need a technician to what determine why it is not working.
Nov 17, 2009 | Beverage-Air MT27 Beverage Cooler...
Fridge sounds like it is running but it wont cool cleaned the dust out of the back and cleaned the filters
Make sure the compressor fan is running. It is probably underneath the unit close to the back.
Have you cleaned the coils? Do they feel extremely hot to the touch?
If the compressor fan stops running, the coils will be very hot because the heat the refrigerant contains is not being released into the air.
Oct 10, 2009 | Refrigerators
On my 2004 duo therm rv roof a/c,I turn it on and to listen to it, everything seems fine.But it`s not cooling properly.I have changed the filter,went on roof, removed cover,motor and fan are working...
on the compressor two pipes normaly one must be very cool .and other pipe very hot this means compressor is ok
if not cooling that much means low charge of freon need repair first the leak then recharge with freon.
Sep 17, 2009 | Heating & Cooling
Wont blow cold air
First check and clean the filters, and the evaporator coil. (thats the "inside" coil that has the indoor air sucked through it, cooling it and then pushing it out the vents.
If the filter is clogged or the coils are dirty, it will not cool properly and potentially freeze up.
Also check the condensor (outdoor) coil, if it is dirty/clogged, it will run hot and not cool properly.
If all coils and filters are clean, and the fan motors are running and in good condition and it is still not cooling then you are likely low on refridgerant. (handling/purchasing refridgerant other than R134A requres a CFC certification by law)
Aug 20, 2009 | Heating & Cooling
Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Jun 11, 2009 | Goodman CKL60AR60 Air Conditioner
I have a u line fridge/icemaker undercabinet model that does not seem to be cooling- it had not been turned on for for quite some time but a few weeks ago we turned it on and it seemed to cool but we...
If compressor is running then unit has a sealed system issue- throw it away unless still under wty. If comp not running then probably bad relay on it. Only way to check is to replace relay. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | U-Line 75R Refrigerator
Maytag MSD2656G Side by Side Refrigerator Logo
70 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
