Disconnect power to the dryer then pull the lint filter out and remove the screws near the opening.
Insert
a putty knife blade or similar tool between the top panel and the front panel
to release the clips securing the top panel to the top of the front panel on both sides as
shown then rotate the top panel up to the rear of the dryer.
Disconnect the door switch wire harness then remove
the front panel screws and lift the pI need to replace valve - ff25db0.jpg off the cabinet.
You
now haI need to replace valve - 8618146.jpgnd view of the burner assembly where the gas valve coils are located.
Disconnect the
wires from the coils and remove the screws from the bracket then lift I need to replace valve - d31ed80.jpgout. Slide the new coils in then secure it with the bracket
and reconnect the wire harnesses.
Reinstall the front panel from the bottom then up and secure it to the cabinet. Rotate the top panel down back into position then push it against the top of the front panel until the securing clips engage and snap into place
The symptom you have indicates weak solenoid coils. The gas valve should open and the burner should ignite every time the glow bar igniter glows before it fades back off. Weak solenoid coils will usually open the gas valve until the solenoids become hot from the current and flame and then they don't have enough power to open the gas valve.
Replace both solenoid coils and your dryer will most heat and operate normally again. In order to access and replace the solenoid coils you will need to remove the front panel.
