Question about Whirlpool Dryers
I have A wirlpool ultimate care II dryer. model # LGQ8000JQ5. When I start the machine the igniter will glow and then the flame will start. When it reaches temp the flame will go out. when the igniter glow again the flame will not start. If I let the machine cool down it will do the same thing. I can see this happening threw the heat tube in the back of the machine
    President:
  • 1,218 Answers
Good day,
The problem with your machine is the coils mounted on top of the gas valve are partially shorted. Starting from cold, they are capable of opening the gas valve, but when hot from a running cycle, they are not capable of getting the valve to re-open.
They are 2 small black coils mounted on top of the gas valve, and are easy to replace. 2 wire plugs and a bracket holding the coils in place.
A very common problem, the coil kit (2 coils) are available at any decent sized appliance parts house.
Posted on Aug 22, 2010
  • John Hall Aug 22, 2010
    P.S. To access the gas valve, you will need to do it from the front. Remove the lint filter. Remove the 2 screws under where the lint filter set. You need to pop up the top lid.
    Using a screw driver pry up each corner of the lid, and gently tilt it away from you.
    Remove the 2 screws holding the front panel at the top, remove the wires to the door switch, and lift the front off.
    The gas valve will be on the bottom left of the cabinet.
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
    Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
    Nov 06, 2012 | Dryers
    Whirlpool Ultimate Care II Dryer Not getting warm
    Could be the selenoid that turns of the gas flow.
    Jul 25, 2017 | Dryers
    I have a roper gas dryer model rdg4440sq0, the igniter glows then the flame lights. Then the flame goes out and doesn't light up again. When it cools down and i restart the dryer the igniter glows and...
    If when the flame goes out ...Check to see that the igniter glows...If it glows and the gas does not light then replace the valve coils...Very common problem.....The coils are to weak to hold the valve open..
    Apr 20, 2010 | Dryers
    Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
    yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
    Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
    Dryer Model DE306 has stopped heating
    First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
    Aug 13, 2009 | Dryers
    Dryer starts but flame extinguishes after a few seconds
    it is clear from your reading symptoms that is asensor thermostat problem
    thanks
    Jul 11, 2009 | Dryers
    How do you light pilot light?
    Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
    If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
    May 29, 2009 | Whirlpool Dryers
    Tub gets off balance during spin cycle
    also,shorten front legs,lean washer forward,and reset back legs.level.
    Feb 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
    The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
    Jan 23, 2008 | Dryers
    Dryers Logo
    126 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
