Question about RCA F25216BC 25" TV
I am trying to connect a DVD player to a RCA F25216BC 25" TV - the TV only has an F type Coax connector and does not have a CH 3 or 4 switch - I put the input from the wall to the DVD player and out to the TV but cant see the DVD input on either CH 3 or 4 of the TV.
  • alexander woolfolk
    alexander woolfolk Aug 22, 2010
    What brand and model number is the DVD player?
  • mikefarr62 Aug 22, 2010
    The DVD player is a Cyberhome DVR 1600
    Guru:
  • 276 Answers
Your TV must be equipped with AV inputs (RCA jacks - yellow, white, red)
in order to connect this unit. If your TV does not have AV inputs, you will need a RF Modulator to connect the DVD recorder to your TV's
antenna/cable input. RF Modulators are available at
major electronics retailers such as Radio Shack or Wal-Mart and allow the 3 RCA outs from the recorder to connect to the RF modulator RCA inputs and then you can connect a coaxial cable from the modulator to the TV RF input and select channel 3 or 4 on the TV. The DVD recorder will not pass thru signals to the TV using coaxial cable as far as DVD are concerned.
Posted on Aug 22, 2010
  • 2 more comments
    I got an RF modulator but instructions was stating to set the TV to channel 3 or 4 and other than the remote channel selector it doesnt have that option. When I hook everything up and turn the DVD on the modulator lights up but the screen just gets fuzzy and no signal comes through. I got Philips Stereo RF Modulator and tied the incoming coax to it and an output coax to the TV. I patched using RCA cables from the DVD player to the RF modulator. Now the RF modulator has a channel 3 / 4 toggle but neither seems to work.
    Connect incoming coax to the DVD recorder's RF input so that you can use its tuner. Connect another coax cable from DVD recorder RF out to RF modulator's RF input and another coax from RF mod RF out to the TV's RF input. Connect 3 RCA cables from DVD recorder's 3 RCA outputs (yellow, white, red) to the RF mod 3 RCA inputs. Your TV needs to be on channel 3 and the RF modulator needs to be on channel 3. Simply tune the TV as normal to channel 3. Use remote or buttons on TV itself (channel up or down)
    Depending on your RF modulator model, you also may have to select the input for the DVD recorder by pushing a select input button on the RF modulator for that input. If you only have one set of RCA inputs on the RF mod (yellow, white, red) then you may not need to select an input.
  • bigjsr1222 Nov 21, 2010
    you might try also putting in a DVD turn it on and then reprograming your TV itselt so it may pick up the channel
Trying to connect a DVD player to a TV that is only equipped with a cable jack what do I do
You need an A/V to RF adapter to convert the audio and video outputs of the DVD player to RF so that you can watch the DVD player on an available VHF channel on the TV. See this device offered by Amazon:
RF Modulator TV Switch Audio Video RCA Ant Input to Type Coax Output...
You may also need a short 75 ohm length of coaxial cable with "F" type connectors on both ends and A/V cables with RCA plugs to complete the setup.
Jan 02, 2015 | Televison & Video
Old TV
I can assume the input for your tv has only a coax input to it. Meaning a threaded connector on the back. If so, first connect the Wii to the input of the dvd player, second, from the output of the dvd player, this is where your solution is needed. run a coax cable from the tv to the DVD player and at the dvd player you will need an adapter from your local Radio Shack or electronics store. It should be a female coax to RCA adapter (male Red White and Yellow).Red and white for audio and yellow for video. Post a pic of the back of the tv if this doesnt solve it for you. Good luck, fingers crossed.
Sep 07, 2012 | GE 25GT240 25" TV
Plugging a DVD player into a RCA J25435?
The DVD player should have a coax cable output on it, You can switch its output to either channel 4 or 3. This channel 3 signal should play on your TV. murf427
Aug 04, 2012 | RCA Televison & Video
How do you connect the dvd player to tv ?
What kind of connection does the TV and DVD have? If it has reg cable you would put the coax cable coming off of the cable box to the in line on the DVD player and then connect another coax cable to the TV. If you have the 3 RCA connectors 1 white 1 red and 1 yellow you would connect it to an input in the back of the tv and follow the colors red to red white to white and yellow to yellow. Let me know if you need more help
Nov 10, 2010 | Insignia Televison & Video
How to connect dvd player to tv
In order of best to worst quality, and depending on which connectors both have.
1. Hdmi ( Video and Sound in one cable )
2. RGB also known as color stream (Red,Blue, and Green RCA ) Sound Seperate ( Red and White RCA )
3. Composite ( Yellow RCA ) Sound Seperate ( Red and White RCA ) sometimes mono (single sound RCA)
4. COAX (cable) which most DVD players don't have.
All RCA connections on devices should be center color coded And grouped by connection Video 1 Video 2 ect.
Mar 16, 2010 | Philips Magnavox DVD Player MWD200F
How to connect to cable box and TV using only coax cables
If I understand you correctly you do not have the RCA inputs on the TV and need to hook up this DVD with a coax cable.
What you will need to get is a RF modulator with both coax and RCA inputs. This will allow you to connect the Cable box up to the modulator with the coax line as normal and then the DVD with the RCA cable to the modulator and then the modulator will connect to the TV with a coax giving you access to both. Here is an example of the type of Modulator you will need.
MODULATOR
Good Luck....
Jan 14, 2010 | Jwin JD-VD502 DVD Player
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
How do you connect to a direct tv box
1st, what kind of Tv Box ? with SCART Connector? or RCA Connector?
2nd, the recoder has a Scart connector or Females Rca connectors.
check for Video IN and L/R input Rca Connector
then use a Scart/RCA cable to connect DVD to TV Box.
Nov 07, 2009 | Philips Magnavox MWR10D6 DVD Recorder
No sound
Steve make sure that the coax is connected to the output on the DVD/VCR and to the TV's cable or antenna input. This should give you picture and sound on CH 3. If you use RCA jacks you must also use the yellow video plug as well on the same input on the TV as well as on the DVD to get both picture and sound to the tv. The place yoou put the RCA's on the TV will determine where the image will be displayed e.g. if connected to VIDEO 1 on TV YOU MUST CHANGE THE TV TO THE INPUT NAMED AUDIO 1. You can do this by using the input or source button on the remote control for the tv or go into the tv's menu and perform the task that way. I hope this helps you resolve the issue. Thanks for using Fix Ya and let me know if I can be of more assistance.
Oct 15, 2008 | RCA DRC8295N DVD Recorder/VCR
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Televison & Video Logo
287 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
