Question about LG Washing Machines
MY washing machine is a top loader, yesterday when my cover broke afetr that when i start my machine it stops after a while and the LED light of the "wash,spin and rinse" keeps blinking.
    Champion:
  • 245 Answers
There is a safety lid switch .One part is on the door the other on the cabinet. You will need to stick something down on the switch to make it continue. Give me a rating if i am correct. Thanks, good luck!
Posted on Aug 22, 2010
I HAVE A WHIRLPOOL TOP LOADER MODEL 3LSR6253E01 MY WASHING COMES OUT COVERED IN LINT. I CANT FIND A FILTER ON THE MACHINE IS THERE ONE? PLEASE HELP THANKS KATE
All washing machine have lint filters to protect the pump, but they generally have quite large holes and although called 'lint' filters, they are to stop baby socks and coins getting into the pump. They are always at the bottom of the machine behind the front kick panel on a front loader or under the agitator on a top loader.
If your washing comes out covered in lint, you need to find the item that is shedding it. May also be paper tissues left in pockets. We only have one item that sheds lint and that is a bathmat. We wash it separately.
Take a look at this video.
Washer Filter Plug Kit part 285868 How To Replace
May 26, 2016 | Whirlpool Washing Machines
Lg front loader washing machine has no power
You will need to unplug the washer, remove the 4 screws from the white plastic pieces on the rear of the machine main top, remove the top by sliding to the rear, locate your main computer board in the top left, plug the washer into the wall, check for a small red LED light glowing on the board. You may have to unplug the washer again and remove the cover in front of the computer board to be able to see the light. If there is no red light your main control board is out, but this could have been caused by another failure such as a faulty stator, or rotor on the motor. Sometimes the connecting wiring from the front control panel to the main rear board will become loose and suffer damage against the moving tub. Best to have a qualified repair company check things out. Pleazer Appliance...
Apr 14, 2014 | LG WM-2277HW Front Load Washer
I have a MW512 5.5 kg top loader, I started a load just a moment ago and after a couple of seconds a repititious beeping sound occurred and a couple of lights flashed at the same time and now I can't...
Ok starting from the spin led light as being number 1 each led light that goes backwards through the wash progress led light indicator is doubled in value i.e. 1,2,4,8,16,32,64,128 and 128 being the longwash led light indicator. Add the value of the lights together that are coming up when it is beeping and that will give a single number that is a fault code and will then be able to tell you what is wrong with it then.
Sep 21, 2011 | Fisher and Paykel Washing Machines
Top loader.recently had sesor replaced after machine went off balance. has gone off balance again, now water pumps for a second then stops and sarts then light sequence comes on.
David, exactly what combination of lights come on, top row. There are 8 leds 5 green, 2 orange, 1 red. Show the code with an X for led on & 0 for light off. EG:
0000X00X
This will indicate F9, sizing issue. (Code is actually read Right - L)
Also is model # GW711 What is product code. Both available on back panel or behind control panel.
Aug 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Problem with my LG washing machine WF-S7012DN model - 7 yrs old. Since yesterday, the wash/m starts to wash takes a turn or two and them stops with alarms on and flashing, (first time problem with my...
there is a magnet controlled switch in the top cover lid and the probable cause the magnet is missing.
The best alternative is just keep a good magnet on the top of lid & slowly move the magnet horizontally.At one point the BEEP stops & machine starts to function.
Jun 03, 2010 | LG WFT1071TP Top Load Washer
GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Nov 26, 2009 | GE Energy Star WCVH6260F Front Load Washer
TOP LOADER KENMORE WASHER FILLS UP BUT DOES NOTHING ELSE.
Sounds like belt is broken. Open front cover and look at belt, if broke replace. If not broke try unplugging for 2 minutes, plug back in then open and close lid 7 times slowly, this should reset the electronic motor.
Jun 05, 2009 | GE WBSR3140DW Top Load Washer
Control Lock is on my front loader.
ok, you are in the model selection part of the service mode. for 6240 I believe the model code is 3 select this and press start. normally to release control lock press and hold small I button by start button.
if model selection in incorrect it can still be corrected. only difference in models is cycles matching the labels. you can tell by the time indication for each cycle if it doesnt look right then check book inside top cover
Mar 29, 2009 | GE WBVH6240F Front Load Washer
Washing Machines Logo
81 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
