Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Mower wont start gas goes through filter but not carborator
  • 472 Answers
YOUR CARB NEEDS TO BE CLEAND OUT AND IT MAY NEED A CARB KIT
Posted on Aug 22, 2010
My l100 wont start but when i put gas in carborator it runs till gas is gone
Not 100% sure but the fuel is either blocked or the line may have a tap that is turned off. Check to see if you have an in line tap that turns 90 degrees, the ears of the tap should be inline with the fuel line, also check to see if the fuel line is pinched or if it was sucked of fuel causing it to collapse. Hope this helps
Jul 15, 2016 | Garden
Sputtering
clogged air filter, or fouled plug, or gas lines plugged, gas filter plugged, or it needs carborator, rebuilt or throw it away
Jul 18, 2013 | Garden
McColloch 7800 generator leaking fuel from the carborator.
rebuild carb using new needle and float if float is full of gas and sinking
Sep 17, 2012 | McCulloch 13HP 338 Cc Portable Generator #...
Either need to rebuild carborator or clean it ?
most small lawn mowers have a carborator mounted on the gas tank.
if you take the screws out and look it has a gasket and the gasket will
be bad and need to be replaced also if it is a newwer model it has a
primer bulb that needs to be replaced at same time.
Jun 21, 2010 | Omega Rear Drive Wheel Snapper Mowers
Changed distributor cap and now van wont start did not have firing order . we now have correct firing order. van was possibly flooded from checking firing order. now carborator is smoking and engine wont...
I would pull the plugs and let the gas into the cylinders to dry out , you may have a hydrolock engine after putting so much gas into it , recheck the firing order to be sure is OK ususlly when you see a carb backfiring and smoking the firing order is not right
Aug 02, 2009 | 1992 Chevrolet Lumina APV
Won't stay started, spitting black oil from carborator
there is to much oil in it . find fillplug remove some oil w/straw until it stop comeing out carb
May 07, 2009 | Garden
Starting trouble after i let it run out of gas
Sediment from the bottom of the tank could be blocking your fuel filter. Replace your fuel filter.
Feb 22, 2009 | 1988 Nissan Sentra 2 Door
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
59 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
