Question about Maytag Dryers
I have a 10 yr old Maytag dryer that has been acting up lately and wonder if anyone can help. I can use the dryer and dry a load of clothes and it work fine. Go to put the next load in the dryer and it not work at all except it will beep at me when I press the start button. Can wait until in the morning and press the start button and it come right back on like nothing happened....almost like it gets too hot and needs the time to cool down before it will run again??? anyone got any ideas of what I can do to fix this problem?? Thanks!!
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 22, 2010
2 Suggested Answers
  • 77 Answers
SOURCE: Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Posted on Apr 18, 2009
My Maytag Centennial elec dryer won't dry well
could it be the thermasat are all the wires connected
Jan 01, 2012 | Maytag Dryers
Have a 7 yr old maytag dryer it seems to heat up fine and everything but we have to redry clothes 2 or three times and dryer vent is not plugged
You possibly have a stripped blower wheel . On Maytags , either blower or clogged vent is the problem when too long to dry . Suggest removing vent hose and feel if you have good exhaust air . If not , blower wheel bad , if so , vent problem . Try drying a load without vent hose connected to dryer .
Jul 06, 2009 | Dryers
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Longer time to dry clothes
Remove the rear connecting vent and run a 45 minute timed dry load. If it works correctly repair the connecting vent and or blockage in the wall.
If this does not correct the problem make sure the glow bar is cycling at the gas valve and report back for further repair.
Apr 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
MAYTAG atlantis MDG6400AW, dryer not heating
no we can fix it its proab a heatyer coil or thermial limiter if you reply ill help mater of fact did you have it on auto dry ?
Apr 03, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
74 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
