Question about Insignia 32" 720p Flat-Panel LCD HDTV
Tv wont turn on after being off for a long period of time. have to on/off repeatedly and finally comes on...but getting worse
  • 11,361 Answers
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
Wpre6100g1wt
there are two possible reasons
1 belt has come off the drum and motor
2 the brushes in the motor have worn down so far that it wont turn.
did it happen all of a sudden, or over did it get worse over a period of time?
May 18, 2014 | LG Washing Machines
My tv will not turn on. I have to unplug it for the green light at the bottom to go off. Then replug it then press the button on the side to turn on. Sometimes it will come on and sometimes it won't. ...
The power processor chip may have corrupted firmware - a set of code instructions written in the CMOS. Take it to a TV repair shop and see if they can re-program it for you.
Nov 01, 2010 | iLO 3200 32 in. LCD Television
TV turns off and on 50 times before finally kicking in!!!!
that is not a bad fuse! you probably shouldnt be doing anything to the set if you dont know what you are doing! These are well known for bad solder around the flyback or glycol leaking from the tubes on the boards inside. i suggest that you get a certified tech to work on this set.
Sep 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
LG Television 37LB4D "Rebooting"
Ours is crapping out just like yours. Picture goes out, "black and white squiggles" appear in the top left of the screen then TV input appears, then it either repeats or gives me my picture back. This happens with both the HDMI slots (tested all 3) and both Component slots. Seems like the bulb or a circuit board on the TV is faulty. What a piece of ****, never spending another dime on LG products. I did get it to come back by hitting the back of the TV with a good slap, but it gets really annoying.
Jun 14, 2009 | Televison & Video
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
TV will not turn on.
Bite the bullet, because it's time for Santa tech to work on this and find the reason for the power supply problem..accordianman
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
36" CRT Toshiba has that vertical issue mentioned on here a bit
Your problem is most likely caused by a cold solder joint in the vertical circuit. Normally this is easy to find and correct. The problem will only get worse over time, but not likely for more damage to occur.
Sep 17, 2006 | Toshiba 36A41 36" TV
Insignia 32" 720p Flat-Panel LCD HDTV Logo
52 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
