Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi VS-5051 50"
TV powers on but have a black screen. I don't know where to get a service manual or what could be the possible problems?
Please let me know. Thanks.
i need a manual for a misubishi television model Vs-5051
    President:
  • 2,712 Answers
Hello sharski,
It looks like you have a burnt out resistor or a faulty convergence IC, or bust capacitors. Most likely the regulator is bad because of bad capacitors. If you do not have any solid state printed circuit board repair experience, I'm afraid the best advice I can offer would be to call in a pro to assist you in this repair.
As for the manual, it is virtually non existant! However, you can try either THIS or THIS, which are pretty similar models..
If you wish, you can contact Mitsubishi Electronics Customer Support at (800) 332-2119.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 04, 2008
  • Mitsubishi Master
  • 13,433 Answers
Most likely a component level problem.
mainboard / powerboard problem.
    Genius:
  • 1,447 Answers
MITSUBISHI DIGITAL ELECTRONICS AMERICA, INC. (MDEA)
9351 Jeronimo Rd. Irvine, CA 92618
Email: mdeaservice@mdea.com to contact us.
MDEA SERVICE REFERRALS
phone: 800. 332.2119 (Online referral;
automated system-must use a touch-tone phone)
THREE DIAMOND® CARD
Customer Service
phone: 800. 656.3005
Manage your account Online
MDEA WARRANTY DEPARTMENT
Mitsubishi Extended Warranty Programs
phone: 800. 888.8245
fax: 949. 609.4912
Document Fax-Back System
MDEA PARTS DEPARTMENT
Service Parts Including Instruction Books and
Remote Controls
phone: 800. 553.7278
fax: 800. 825.6655
MDEA CONSUMER RELATIONS
Product Information, Brochure Requests,
and Customer Service Assistance
My vs-60607 has waving lines
postive 9v regulator on the signal board and possible capacitor right next to it. the regulator is generic 7809. if you test the output it will be 6 or 7v needs to be 9. when the lines go away it is warm and will read 9v. so do the test cold. i'm assuming you know how to use a multimeter. if not then a local repair shop can do this for you.
Jan 01, 2009 | Mitsubishi VS-60607 TV
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
Jun 07, 2008 | Mitsubishi VS-60607 TV
Repair help
Good Day, limao247;
Your TV may fluid on the PCB's. Remove the speaker grill, the small panel and look closely for fluid on the boards towards the front. Always unplug the TV for your SAFETY. If you find fluid clean board with acetone. Good Luck, big IRISH.
Aug 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-6041 60 in. doesn't power up
Hello Tremulant
This denotes a possible problem with the Low or high voltage power supplies. The clicking you here might be the shutdown circuit acting because of excessive draw of current. The problem will most likely be associated with the HV power supply, but you will have to have a qualified TV technician check your TV to make sure.
I hope this helps,
Thank you,
Shuttle83
May 31, 2008 | Mitsubishi VS-6041 60" Rear Projection...
No picture
Are you sure its not a VS60603 ? VS80803 is not a valid model number for mitsubishi. If it is a VS60603 you can get a manual at the following link and they will contact you asking if you would like it emailed instantly. Its 10.99 for the Manual. Heres the link
they have quite a few Mitsubishi as well as other models and they offer free support with the manual.
http://servicemanuals.vstore.ca/
Jan 23, 2008 | Mitsubishi VS-80803 TV
Mitsubishi VS-50501 - Black Screen
Is the power light staying on? If so press imput and menu together for 5 seconds to see if the set will blink a 2 digit repeating code. If that doesnt work. Check for CRT coolant leaks on the boards. This seems to happen alot as do faulty capacitors. Coolant leaks will be located on the chassis directly under the tubes they can cause corrosion and prevent your set from starting especially in the VS models.
Dec 30, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Jun 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
146 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
