Question about Dell E228WFP LCD Monitor
How fix error dell: auto detect digital resolution
2 Suggested Answers
  • 10406 Answers
SOURCE: I keep getting the following error: Auto Detect
Right-mouse click anywhere on your computer's "wallpaper".
Click Properties.
Click Settings.
Move the screen-resolution slider to 1680-by-1050.
Click Advanced.
Click Adapter.
Set the adapter to 60 Hertz.
Click OK.
Posted on Apr 09, 2010
Auto detect analog
Hi Jessica,
Dell E228WFPC/E228WFP does support displays with 1920x1080 set resolution via DVI connection while it is restricted to validated Dell brand displays:
  • The restriction applies to resolution higher than 1680x1050 via DVI connection.
  • No restriction with VGA connection, which supports up to 1920x1200.
If you use a DVI connection set your computer's resolution to 1680x1050.
http://downloads.dell.com/Manuals/all-products/esuprt_electronics/esuprt_Display/dell-e228wfp_User's%20Guide_en-us.pdf
Feb 19, 2014 | Dell Computers & Internet
Monitor 1707fpt
I would suggest you try this to fix your problem. Go to Control Panel from the start menu if you are using Windows 7 and Windows Vista. Click on the Display Setting and adjust the screen resolution to the recommended Screen resolution. On the Display Setting at the top of the you should see number 1 and 2 with a large box ,on the right side of these boxes there is a menu that you can click on, these menu are {Detect and Identify} click on Detect first and then Identify. I hope this solves your problem.
Jan 05, 2014 | Dell Computers & Internet
Mi problem its po371 howcan I fix my problem my car is 2002 nissan altima 2.5
What does this mean?OBD Code P0371 refers to the optical sensor which provides a high resolution signal to the Powertrain Control Module (PCM) by counting pulses on the sensor disk located in the injection pump. The high resolution is one of the most important inputs by the PCM for fuel control and timing. This test monitors the number of high resolution pulses which have been missed (not detected). It's based on a comparison between the number of pulses that were detected since the last pump cam pulse and the number of the pulses that should have occurred. There are approximately 64 high resolution pulses for every cam pulse. SymptomsPossible sumptoms of OBD code P0371
- Engine Light ON (or Service Engine Soon Warning Light) CausesPossible causes of OBD code P0371
- Open or short in the optical sensor circuit - Optical sensor connector - Damaged optical sensor - Damaged PCM or ECM The Error code is generally activated on detection of the following conditions: There are too many high resolution pulses from the optical sensor to the PCM Possible Solutions- If damage, repair optical sensor circuit - Replaced optical sensor - Replaced PCM or ECM
Sep 28, 2012 | 2002 Nissan Altima
I'm getting this error message "chipset heatsink not detected system halted" What does that mean, and is there a fix for it?
it means that the chipset heatsink on the motherboard has come loose. There is a sensing circuit that is closed by the spring clip that holds the heat sink in place. One of the loops on it has broken, causing the error.
Resolution is motherboard replacement
http://shop.ebay.com/i.html?_from=R40&_trksid=m570.l1313&_nkw=dimension+4600c+motherboard&_sacat=See-All-Categories
installation information:
http://support.dell.com/support/edocs/systems/dim4600c/sm/parts.htm#1102134
Aug 08, 2011 | Dell Dimension 4600C PC Desktop
I keep getting the following error: Auto Detect (digital input) Cannot display Video Mode Optimum resolution 1680x1050 60hz
Click Properties.
Click Settings.
Click Advanced.
Click Adapter.
Click OK.
Apr 09, 2010 | Dell E228WFP LCD Monitor
Unsupported Video Configuration Detected
Apparently you set a video resolution which your monitor isn't able to handle. Try booting in safe mode by holding the F8 key at boot, then change resolution to something safe such as 1024x768. Reboot in normal mode and set the resolution you're most comfortable with.
Oct 29, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Lost the screen resolution 1600X900. How do I get it back? Its a Dell S2009W. Worked fine until I had computer problems. Now all my photo people are fat.
You can set the resolution on the computer. Right click an empty space on the desktop and then click Properties. In the properties dialog box click Settings. Now use the slider to change the resolution. Click apply.
Sep 25, 2009 | Computers & Internet
How to play movies from computer on tv?
if your tv has vga in, then you need a vga to vga cable (like a screen wire) then change the resolution in the settings of windows (put 800X640 resolution before you plug tv so that you can know what is supported)
if it doesent then you cant do anything other than buying a video card with hdmi or dvi (with a dvi to hdmi) with a hdmi cable then plug it in (will auto detect)
Dec 18, 2008 | Dell Inspiron 531S (DDCWGA1_5) PC Desktop
ATI RAdeon HD2400 in Dell Optiplex 755.
From the AMD.Com website: Display Support
  • One Dual-Link DVI-I connector for high-resolution digital displays
  • ATI Radeon™ DVI-I to HDMI2 with 5.1 audio (adapter)
  • One VGA analog connector
  • HDTV Component (YPrPb) output (adapter)
  • Drive two displays simultaneously with independent resolutions and refresh rates4
  • TV output requires HDMI, component, S-video or composite cable (not included)
Two integrated DVI display outputs
  • Primary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)1
  • Secondary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI only)1
  • Each includes a dual-link HDCP encoder with on-chip key storage for high resolution playback of protected content2
It does using dual link DVI. Is that the cable you are using?
Here is a link to the complete specs
Sep 15, 2008 | ATI RADEON HD 2400 PRO Graphic Card
Low resolution/pixels on "auto" mode
Download the user manual HERE and it will tell you exactly how to change the setting.
Is an easy fix when you know it
May 02, 2008 | Canon PowerShot S3 IS Digital Camera
Dell E228WFP LCD Monitor Logo
237 people viewed this question
Alun Cox
