Im using XP and my defragment always hangs at 15% and it hangs, also my pc runs slow what can i do to fix this
  • yan dikshteyn Aug 22, 2010
    awesome very helpful thank you
  • 2,973 Answers
Yannii, Please go to www.download.com and search for dfrag tools. Use one of these free tools and see better results on defragmentation. As regards the slow speed of your computer, this is most likely due to the over blown Windows Registry. Read the link below carefully and follow it. Even I was suffering from the same problem last year. My laptop used to take 25 to 30 minutes to boot. And was sluggish even after that. I use Ccleaner and it has been galloping eversince.
http://www.fixya.com/support/r3876210-computer_slowing_down
http://www.fixya.com/support/r3812010-search_drivers_online
Posted on Aug 22, 2010
Hasee laptop
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer freezes problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 10, 2013 | Crock Pots & Slow Cookers
My laptop may be one of my problems when surfing the internet. after i turn my laptop on, 10-15 mins goes by hang, the coolant fan starts running at a high speed, and at the same time slowing my...
you might ask Why is my laptop to running slow? well, this is the most common error that people are complaining, there are lots of things that may have caused your pc to run slow, it might be a virus, registry problems, need a faster RAM. try to scan your pc with antivirus.
May 07, 2011 | Office Equipment & Supplies
Always hang,and slow,system
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Oct 20, 2010 | Intel Pentium® 4, 2.26 GHz (SL6PB)...
Pc runs very slow
If under 256mb ram with windows xp, get some more ram.
Uninstall unwanted programs, remove un needed programs from the startup folder.
There is a complete guide here to clean your computer
http://www.fixya.com/support/r5272277-secure_clean_computers
Jul 20, 2010 | Toshiba Satellite A105 Notebook
Hello there: really just looking for some solid advise this hp52w w has the original xp operating system in it with sp2 installed works ok but it gets so slow on the starting windows screen it takes...
Hello Mike, Hi, may I suggest you try first to defrag your hard drive, Im sure when you power on your PC, the hard disk led keeps on blinking, your hard drive may have developed bad tracks and sectors, this slow moving process tends to go forever.
Defragmenting and checkdisk can find faults and bad sectors and tracks that slows down the performance of your PC.
Reformatting should be done if your defragmentation procedure fails to speed up your PC.
Try to run an antivirus program, which may help speed up your PC by detecting viruses, that tends to load forever, or slow down the booting process.
Nov 24, 2009 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
My son's PC *always* needs to be booted twice to get it up in Windows XP Pro. For some reason it hangs during the first boot. Once it hangs you have to push'n'hold the power button to force shutdown, and...
You can do a bit of detective work and run MSCONFIG.EXE froma command prompt and go through that - particularly the boot, services and startup entries. The startup entries in particular - as from there you can select what is and what is started at startup - and a process of elimination can maybe help you track down the problem. 'Registry cleaners' may help - but often are more problematic themselves thn they are 'fixers'. You could edit the registry by hand, using regedit, but that is NOT recommended unless you really know what you are doing. Do note that if you change the start-up programs (i.e. change their enable state), you will get a warning at start-up that you are running a custom start-up using msconfig.
As a last resort, a fresh installation of Windows will fix things. Running a virus checker might also be a good idea.
Allan
Nov 03, 2009 | Computers & Internet
My Toshiba satellite Laptop is very slow
i had the same problem with my computer. it may be that you have downloaded too many things. it loads onto your RAM storage, (computer files), and when it gets full, it goes onto the harddrive, (where you access files and things). clear up internet files and anything you don't need. if that is stilll slow upgrade your RAM. it fixed my pc
Jul 27, 2008 | Toshiba Satellite A100-S8111TD Notebook
Window stops in middle of session have to shut down and restart computer????
hi im wesley. you might have a virus of some sorts or try defragmenting your pc it will also speed it up as this sometimes happens when you have alot of things on your pc and when you delete stuff and put files on all the time it slows down alot and can hang because the files are mixed up on the hard drive. to defragment go to start-all programs-accesories-system tools-defragment then say analyze then defragment.
Jul 14, 2008 | Gateway Computers & Internet
Acer aspire 5100 + AMD TURION 64 + DDR2 1GB + WINDOWS VISTA - IS VERY SLOW, AND HANGS
hmmmm...now..that's weird..did you do any disk maintenance? shut down all applications, all of em, and run disk cleanup and defrag..usually good for about 25% improvement in speed, at least..
got backup for that acer?
Feb 21, 2008 | Acer Aspire 5100 3010 Notebook
Open Questions:
Can I hold DHHS accountable for the burden they put upon me? If not, is there someone that can be held accountable? What can I logically and honestly do to remedy this prob. I explained my prob below! I was getting QMB part of Mainecare and my spouse at the time we were dating but living together was getting the QI part of Mainecare. We are both disabled and only get SSDI. However being honest and do our best to always do the right thing we go to DHHS office on Griffin RD in Bangor, ME within a month of us getting married where the worker we saw tells us we don't qualify for anything but the min of FS and both Q1 part of Mainecare and serious voice tells us to divorce. I have made a few trips within last months to same DHHS. One sends us to Eastern Area of Aging to see if there were secondaries we can get. This past Monday hubby and I went to our appt with Eastern Area of Aging & was told they strongly believe I could get spousal exclusion also warning it could mean my hubby loses help but because it was a volunteer a newer one at that she couldn't tell me definitely cause she didn't know the formula as she still learning; tells us to go back to DHHS to ask about spousal exclusion. So I go back to DHHS this past Thurs and got a worker with more smarts, heart with approx 10 yrs working for DHHS tells me I qualify for spousal exclusion and took the time to answer all my questions. I told her I had QMB till hubby and I married June 2016 & shared with her what the DHHS worker told us when hubby and I went in to show marriage certificate to update the change. She looked at me with shocked eyes and dropped jaw in bewilderment. Then says I would of never lost it as I would of qualified for spousal exclusion from the day we married. And had it been her that we got when we were being honest wouldn't have only told me about spousal exclusion but would of applied me as she could see I have major medical problems that is too much a financial burden for my hubby and I. She also told me I was to submit all unpaid bills even if monthly making payments were being made. I thought I was only to submit bills I paid in full or on a payment plan. So started Thurs night on a Medical Bills Tracker to go through all the medical bills and sort things out. I haven't even put a dent in the pile and see I'm responsible for just over 6K I'm predicting once done I could be closer, if not over, 10K. In collections is currently 1K but once done with pile amount in collections could be closer to 2K or more. So the mess has impacted my credit and if things were done by professionals I wouldn't be losing my hair stressing over my medical bills and how it declines my credit. I know I'm in a small group that actually pay their medical bills any and all bills to be honest! I am disabled and get SSDI. Worked 1992-2013 a lot of times working 2 jobs! Dr in 2013 practically dragged me out of work as was just diagnosed with Hep C, CKD Stage 3 & liver disease! I also have depression disorder, panic attacks, anxiety disorder! So even this incompetent DHHS worker putting extra financial burden on me unnecessarily affects those things. I am trying to do the right thing but get kicked down by the very people that are paid to help me. What are my rights and can I fix this at a faster pace then not even fixed it by the day I die?
Jun 23, 2018 | Major Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
