SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: craftsman riding mower blades won't disengage
Sounds like the shear bolt is broken, Do you have and owners manual to show you the location of shear bolt? They are easily replaced.
SOURCE: Craftsman riding lawn mower 15HPOHV model 28N707
14.5 craft riding lawn stop moving i dont know what to do
SOURCE: toro lawn mower model 11-
sounds like the belt broke or jumped off the rear pulley.
don't forget to vote for me.
thanks
