Question about Craftsman Garden
I just purchased a 2000 craftsman riding mower with a double rear bagger. I do not know how to make it **** up the grass. The only thing it was doing everytime I moved the knob was mulch the grass and none went into the
  • 472 Answers
YOU HAVE THE WRONG BLADES ON IT
Posted on Aug 22, 2010
Cutting grass but it isn't going into the bagger?
grass catchers need special shaped or good blades to throw the cut grass into the bag
check/ replace the blades
May 06, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Do I need to switch to the high lift blades for my rear bagger to work right?
Yes. I use gator mulching blades during the summer. They won't bag a thing. The original/standard blades will bag some grass/leaves, if they are dry and not too dense, but they are prone to clogging. The high lifts work much much better.
I get mine on amazon. The shipping is free. LA145 48" deck. Part GX21785.
http://www.amazon.com/gp/product/B00CAXMAG2/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1#product-description-iframe
Apr 13, 2015 | John Deere Garden
I canot get a bagger kit for the 54inch cut lawn tractor in UK, can a 48, bagger be fitted and altered to fit which I can get in the UK
I have never seen a catcher for this size of deck, Husqvarna do not offer one, i am sure the deck aperture is different from the 48" machine, if the catcher is available in the US, would they just supply the upper and lower chutes? the 52" deck produces a vast amount of grass, so will fill the boxes very quickly, you would spend more time going back to the dumping area than actually mowing, mulching would be a much better option, if you have to collect would a tow sweeper not be better, it holds more grass, and you would not have issues with poor draught, and grass blocking in the chute ( a big problem with noise compliant machines, and damp grass , and side ejection )
Oct 10, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Have a Craftsman LT1000 and the discharge pipe on the grass collection tube continually gets clogged. The grass is not wet or overly thick and the blades are sharp. Engine RPS's good and i always cut...
Inspect the inside surface of the discharge tube. If you do not find any hangups, then I would wonder how fast you are mowing. If you are going full speed, I would recommend that you slow just a little. I was just thinking, have you been doing the same thing for a long time and recently have this problem develop. So, give good inspection. I do not know what type of bagger you have, but is the air able to escape the bagger, if it is not then it sets you up for a clog. If you can not find anything on detailed inspection of bagger system, there are sprays for under the deck of lawnmowers to minimize the chance of grass clinging to the underside of decks, you could try applying that to the ducting of your bagger. I hope this is helpful.
Aug 22, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Why does grass get hung up in the chute for a rear debagger?
Typically, wet grass or tall grass will get caught. Mow only when dry and make sure your blades are sharp. Mow with the engine at full speed [VERY IMPORTANT] adjust your ground speed by using the proper gear for your conditions. With the engine at full throttle, choose a lower gear when cutting higher grass. Make sure the air outlet of the rear bagger is unobstructed. It has to be able to breathe.
I trust you will find use of these techniques will lessen the clogging rate you are experiencing.
Thank you for your question @ FixYa.com
Jul 11, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I just purchased a poulan xt 38" riding mower and am wondering if this is the correct bagger for this. My model # is PXT12538.
If your tractor is 2006 or newer then yes this is supposed to fit. This bagger will also fit some craftsman mowers.
Jul 22, 2010 | Husqvarna #QCT38 960720001 38" Dual Bin...
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
How do I install the grass collector
Assuming that you have the correct grass catcher..... Install the discharge deflector at the deck discharge. This is the smaller piece that bends 90 degrees. It will slide into clips on the deck when you have the deck's plastic deflector raised up. Next, install the bagging assembly. It's pretty straightforward. Lastly, install the plastic chute (tube). Push it in the grass catcher (bagger) opening, and then pivot it over the deflector and down onto it to seat it. Connect the straps.
Best regards, --W/D--
Aug 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Chute for bagger keeps getting clogged
John Deere LA 125. Chute keeps clogging up with grass.
Apr 22, 2009 | Garden
Garden Logo
149 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
