Question about Toshiba Satellite M30X Notebook
I don't know what to do
When I turn on laptop my usual screen doesn't come up. I get a system error box saying 0201:Failure IDE#0 Do you want to run setup? Went through some of the steps but the Error box just comes up again and again.
  • Anonymous Jun 07, 2008
    Same exact problem. hmmmmmmmmmmm
  • Toshiba Master
  • 13,433 Answers
Seems the harddrive in your laptop has failed or is loose.
most likely you need to buy a new harddrive for your laptop.
Posted on May 04, 2008
When I turn on HP pavilion windows 8 os it says starting automatic repair and then goes to black screen
this is a commom issue with windows 8 on HPs. turn off your automatic updates then contact windows. the updates usually gets to 13% and then freezes.
Jul 27, 2013 | HP Pavilion Computers & Internet
Will turn in but won't really start up, message pops up sayin I have problems on my laptop but it can't fix them? Read description
When your toshiba splash screen is showing on startup, press F8 continuously, then you should get some options, go to the one that says safe mode. After loading windows in safe mode click start, search, and type system restore. Open system restore, find a date where your pc was working correctly and click restore. If this doesn't do it on the toshiba spash screen (if you have a new enough laptop) there will be an option called system recovery usually f11 key, this will restore your pc back to its factory state and should resolve any problems your having. If you don't have that option go to https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp and see if you can order a set of recovery disc's for your model, they usually run from $25-$30. Hope this helps.
Mar 01, 2012 | Toshiba Computers & Internet
IDE #1 Error
the hard drive is malfunctioning./ pls chesk the power connector and replug
also data cable
the hard drive controller overheating ? pls check and go to bios and detect again
Jul 17, 2017 | Toshiba Satellite 2800-S202 PC Notebook
When I download a program an click to install it a box pops up saying the download I am trying to install is not a valid Win32 application. This is a new problem. I have not had any problems downloading in...
This error message could be caused by a number of things. Generally it's because the program being downloaded is corrupt or didn't download completely. Have you tried a different browser to do the downloads? If it's a very large download you may encounter problems with losing packets. A download manager may help.
http://www.techspot.com/downloads/231-free-download-manager.html
Also, you may want to try doing a restore to system restore point to a date when you weren't having this issue. System Checkpoint dates (in bold) are usually very safe points to restore to. I would also recommend a virus scan and if you don't have this utility and are able to download and install it (yes I know that's your current problem, but you can download it to a flashdrive from a friend's comp and install it), I'd get Glarysoft Utilities and run the one-click maintenance which will fix any registry errors. It's free and is a great way to keep your machine running well.
http://download.cnet.com/Glary-Utilities/3000-2094_4-10508531.html
If any of this helps correct your problem I would appreciate a rating. People here seem to take the help and don't show any appreciation by taking the time to rate the help.
Jan 11, 2011 | Computers & Internet
Media Test Failure, Hardware Problem?
reset your BIOS settings to default, to do this go into BIOS screen and choose return to default settings.
Jun 17, 2009 | Acer Aspire 3680 Laptop
Toshiba Satelite M35-456 Error 0201 Failure IDE #0
Here is the Toshiba official line on that error.
If you've already run through their fixes, you could try using the Ultimate Boot CD to test the hard drive, or run Chkdsk c: /r from the recovery console to attempt to recover any bad sectors
Then consult this link and apply the pertinent fixes to attempt to repair the MBR.
Other possibly helpful links here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 17, 2009 | Toshiba Satellite M30X Notebook
Toshiba latop 0201 #ide problem
IDE #0 is your primary hard drive.
Toshiba's System Errors indicate that the error 0201 Failure IDE #0 may be caused by bad contact points where the drive plugs into the laptop chassis. Toshiba recommends pulling the hard drive in and out several times to clean up the male/female contact points.
Toshiba also said that if this doesn't work to contact one of their service centers for assistance.
The contact points solution rarely works, but is worth a try. Most likely, your hard drive failed and needs to be replaced.
Feb 08, 2009 | Toshiba Satellite M30X Notebook
IDE 30 ERROR
re insert the HDD and try again or else go in the cmos if it is detecting or not..if not detecting,maybe it is loosen in connection or else the HDD is DEAD...
Jul 11, 2008 | Toshiba Tecra M2 Notebook
Sony VAIO laptop; DVD-R not reading disks
Check the status of the device in Device Manager to make sure that the device driver is working correctly. (If you need help doing that please ask.)
If no joy then:
Change the transfer mode for your CD drive in IDE Channel Properties loadTOCNode(2, 'resolution'); loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. On the right side, expand IDE ATA/ATAPI controllers. 4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel. 5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK. If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved: • Primary IDE channel, device 1 • Secondary IDE channel, device 1Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
Jul 05, 2008 | Computers & Internet
Toshiba Satellite M30X Notebook Logo
315 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
