Question about ASUS A8N-SLI Deluxe Motherboard
4 Gigs or Ram?
I have 4 gigs of matched Patriot ram. 2 sticks work fine in the correct slots. When I add 4 Total it does not. Any suggestions Please? Thanks very much.
    President:
  • 2,351 Answers
Have you taken a look at page 2-12 in you're manual? Than re-check pg. 2-11 (Read everything) when setting up the Max memory of 4GB.
Mike
Posted on May 04, 2008
Unable to add more match RAM using secondary slots
You need the motherboard manual to make sure it can take more.
It may only accept 4 gig. For example: 2 x 2 gig strips or 4 x 1 gig strips.Or you may need to use single sided ram boards, chips on only one side. I know some motherboards do.
Feb 07, 2012 | Computers & Internet
I have recently upgraded my brothers Acer T180 computer with approved crucial 2 x 1GB ram ddr2 PC2-5300 667 NON ECC UNBUFFERED CL5 which was scanned by the crucial website and purchased from them. When the...
Some motherboards are only upgradable to their allotted amount that board may only handle up to 2 gigs of RAM which is a shame. But this is the way it is. That is why I always check the board memory capacity before I buy computer boards or RAM for them. The beeps indicate error on the slots for the RAM that is why you can start up when you remove ram one at a time and replace. So use the allotted amount of RAM for that board specification or get another mother board that can handle more than 2 gigs of RAM. Sorry for the loss. Thanks for using FixYa! John
Apr 13, 2011 | Acer Aspire™ T180 PC Desktop
I have an Acer Aspire 7540-1284 laptop that came with 3GB memory. The specs say expandable to 4GB but the manual says expandable to 8GB using soDimm modules. I can't find info anywhere to support...
it prolly has 2 ram slots, capable of holding a 4gig ram stick apiece- for a total of 8 gigs.
however, the largest ram stick they currently make is 2 gigs. your board can support 2x4gigs of ram (8 altogether), buit the most ram you can currently purchase is 2x2gigs (for 4 gigs altogether).
additionally, you have to have a 64 buit version of windows to regognize all 8 gigs if you had them.
a 32 bit version of windows will recognize no more than 4 gigs of ram.
May 22, 2010 | Computers & Internet
2 gig ram sticks
Not with Windows XP, because more than 3 gigs isn't useful. Many servers come with 8 or more and nearly any computer you configure at the major manufacturer's websites can be bought with 8 or more.
Sep 19, 2009 | ASUS P5VD2-MX SE Motherboard
I have a question on how to add RAM to an Intel D850MV.
According to specs your board can max out at 2GB. So you could fill all slots with 512 Gb sticks, 1GB total in each bank. You should always match RAM in pairs. You should be able to add just 1 stick in second bank as long as the first 2 banks are filled.
Char S
May 21, 2009 | Intel D850MV Motherboard
Windows XP Professional x64 Will not start up with more than 2gb.
Move your ram into different slots, put different ram in slot 2 or 3, sounds like bad ram, 32 bit apps access ram VERY diferently that 64 bit apps.
Mar 25, 2009 | Microsoft Windows XP Professional x64...
4gigs ram
Switch sticks around in various combinations (2 gig in slot one, 1 gig in slot two, switch, try other stick, etc) and see if it is the memory or the motherboard.
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Double boot
almost anything is possible, but in general a 430 watt P/S should be able to run 2 gigs of ram, however that doesn't mean that the ram you purchased is the correct ram for the motherboard or that you have so many other added perpherials i.e. dual or tripe CD drives, hard drives, USB perpherials that the load is simply to great for your P/S. A rule of thumb is find out what your system ' will ' run with and then work from there. For example if a person was serous about this problem he might disconnect all power connectors to all other equipment other then his hard drive, monitor/video card, and his motherboard just to see if the system could then boot normally. If it did, chances are the memory is okay for the motherboard in normal circumstances. However if the system did not boot normally, it might be an incompatibility with the 2 gigs of memory on that particular motherboard. Memory is not a generic add-on. A person needs to make sure the memory is correct for a motherboard before installing. Also you indicate the present P/S is only 4 months old, any particular reason why you had it changed out to begin with??
Feb 27, 2008 | Biostar P4M80-M4 Motherboard
Not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Jan 17, 2008 | Compaq D310 (287944-CTO-4) PC Desktop
2 gigs of ram
Re-check your manual at pg. 1-12. 1.9.1 Memory Configurations.
Since you know one bank of memory works fine in a certain slot. Now try the other in the same slot.
Jan 15, 2008 | ASUS P4PE-X Motherboard
ASUS A8N-SLI Deluxe Motherboard Logo
100 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
