Question about Dryers
I have a kenmore 80 series gas dryer. at first, when i pushed the push to start button, the dryer would hum but not start. now, all i get a clicking sound similar to a relay cycling.
    Champion:
  • 245 Answers
Your motor is bad sorry.
Posted on Aug 22, 2010
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
I have a Kenmore 80 Series dryer. When I push the start button it makes a noise but won't turn on or it turns on for a few seconds and then stops
Did you figure out what the problem was? I have the same problem with my Kenmore dryer.
Thanks
May 17, 2010 | Dryers
Dryer will not start upon pushing the start button.
the motor is more than likely bad but just to be safe check the blower wheel and make sure there is not anything in it then remove the belt and try to turn motor if the motor feels real tight then you need to replace the motor
Sep 18, 2009 | Kenmore 63942 Dryer
Kenmore 80 Series Gas Dryer won't run unless empty
MORE THAN LIKELY YOUR TENSION PULLEY IS SHOT WAS IT MAKING ANY SQUEEKING NOISES
Aug 26, 2009 | Kenmore 73952 Gas Dryer
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Kenmore 90 series won't start
You have a bad motor.
It must be replaced.
Mar 31, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Kenmore 80 series dryer, won't turn on
Thanks for the question When you push the start button was thera hum if there is a hum when you push start you need a new motor THanks for the question The appliance doc
Jul 18, 2008 | Kenmore 63942 Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
