Question about Fisher and Paykel Washing Machines
After moving machine the hot and cold were reversed when reconnected...hot and cold water was reversed after correcting supply lines now hot will not woek cols is ok....is this a damaged sensor issue?????
    Champion:
  • 245 Answers
That's just a coincidence. You just need to replace the inlet valve. Might want to check for any obstruction in the water hose line and screen first. Give me a rating if I am correct. Good luck!
Posted on Aug 22, 2010
Need to know what HC means on my washing machine Kenmore Elite Oasis. wash did come thru from the bottom
hi there
HC means that the water hoses have been changed or the hot is in the cold and vice versa. put the hot water to the hot on the machine and the cold to cold and this will stop the HC code.
and on another site
The "HC" indicates that the Hot and Cold water supply lines are reversed. Shut the cold and hot water supply valves off and then remove and reverse the hot and cold water fill hoses on the washer and then see if it continues to display "HC".
what HC means on my washing machine Google Search
Aug 07, 2017 | Kenmore Washing Machines
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My maytag washer model lat8006aae hot water flows in slow. I reversed water supply lines, no change, replaced water strainers and new water lines, still slow flow. supply lines, inlet water valve
It is possible the hot cold switch is flawed and stuck on mix of hot and cold I would have the inlet valve checked with a multi meter they can also check it for u at most appliance parts stores
Feb 07, 2015 | Maytag Washing Machines
Washer fills with hot water on cold wash or rinse. Turned off the hot water supply during cold cycle and machine stopped filling. Checked that the hoses were connected to right inlet valve and they are.
typically hot is on the left and cold is on the right at the house faucets but in some cases they are reversed so if filling with a cold setting and the right side supply is hot the plumber reversed the lines when the house was built which while its semi rare has been seen numberous times
Sep 26, 2011 | Whirlpool GHW9250M Front Load Washer
The cold water line now takes a long time to fill for a rinse. Yes, I checked the hose to its wall outlet.
FYI, Only 3 potential issues would typically cause this problem.... in order of simplicity to correct:
1. Clogged screen in the water connector(s). Remove the cold water line going to the washer - both ends. Inspect and clean the screen(s) and blow through the hose to varify that it is clear.
2. Solenoid that allows water into the washer is failing. Reverse the cold and hot hoses. Does the problem move to the hot side? If so, the problem is the solenoid-replace it.
3. If number 2 does follow the hose transfer, the faucet washer has broken and is blocking the water flow. SHUT off the water supply to the house, open another faucet to relieve the water pressure, replace the washer in the cold water shut off valve at the wall.
Jun 02, 2011 | Kenmore 22622 Top Load Washer
The electronic cold water inlet valves at the top of the machine are leaking. My manual does not list the part and i need to replace it. I dont know the correct part name or number
Water Inlet Valve Replacement Procedure
Cold water inlet valve assembly: Part # 5221ER1003A
Hot water inlet valve: Part # 5220FR2006H
  1. Safety first. Unplug the machine.
  2. Close the water supply valve.
  3. Remove the cold water fill hose and drain the residual water into a pan or bucket.
  4. Remove the two screws on the back of the top panel securing it to the cabinet.
  5. Slide the top panel to the back of the machine and lift it off the cabinet.
  6. Disconnect the wiring harness connectors from the valves. Mark the connectors to make sure you reconnect them to the right valve.
  7. Unscrew the valve assembly from the cabinet and pull it out.
  8. Loosen the hose clamps and remove the hoses from valve assembly.
  9. Connect the hoses to the new valve assembly. Reinstall the valve assembly and the top panel in reverse of the steps above.
  10. Reconnect the fill hose and open the water supply valve.
Jan 26, 2010 | LG WM-2277HW Front Load Washer
Hot water runs when it should be cold and the cold water is turned on
turn your water off and remove your hot and cold lines and reverse them sounds like you have your hot and cold water supply lines reversed..
Jul 30, 2009 | Maytag Bravos MTW6600T Top Load Washer
Maytag performa washer hot/cold now reversed
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Feb 26, 2018 | Maytag Performa PAV2200
Cold water or cold & hot water connection?
If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
Apr 11, 2009 | Bosch Washing Machines
My laundry comes out hot to the touch. I used the warm/cold setting....
Check to make sure your Hot and Cold water lines from your supply are correctly attached to your Washer. They are labeled on the back of the machine, if you reverse them you should have a cold water rinse.
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
