Question about Hotpoint Refrigerators
I can't seem to get my Hotpoint refrigerator cold enough and am concerned about food poisoning. It seems to stay at 40 degrees/ It's model #HTR15A 13MBRAA Serial @SA 747001. It says to turn the knob in the upper center inside the refrig to the coldest to 9. I don't know whether to turn it clockwise or counterclockwise. Since I live in an apt., there was no manual provided to me.I need help asap.
  • Hotpoint Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 22, 2010
Have a Kenmore side by side refrigerator freezer gets cold but refrigerator side stays at 40 degrees
The refrigerator of fresh food side is supposed to be around 40 so its working correctly.
Feb 27, 2015 | Kenmore Refrigerators
My Sub Zero 550 model seems like it is running all the time. It is too cold in the refrigerator compartment,and the condenser fan runs constantly. Adjusting down the temp control has no effect. Freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 15, 2010 | Sub-Zero 650 / O Bottom Freezer...
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
Step 2
Place your magnetic thermometer in the refrigerator.
Step 3
Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
Step 4
After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
Step 5
Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
GE fridge/freezer on but no cold air
The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
Mar 07, 2010 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
I JUST INSTALLED MY REFRIGERATOR BUT THE FREEZER DOESNT SEEME TO BE GETTING COLD ENOUGH TO FREEZE FOOD
HOTPOINT (made by G.E--enough said). Do you already have food loaded into the unit? If so, how warm is it, and do you have it packed up to the vent?
Jan 29, 2010 | Hotpoint HSS25GFP Side by Side...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Sep 22, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
