Question about Coffee Makers & Espresso Machines
I have a Siemens make imported espresso coffee making machine model TK 64 series surpresoo S 40. Need servicing / repair professionals at bangalore
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
  • 2039 Answers
SOURCE: DeLonghi automatic espresso machine
do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
Posted on Feb 08, 2008
SOURCE: Need repair service in Denver, CO
Call Maric Beverage Systems they are very knowageable & the best service company in my opinion on Nuova Simonelli as well as all the others. 719-380-1610
Posted on Sep 09, 2009
SOURCE: Need a repair manual for Saeco Italia Espresso machine
I need an instruction manual and I need to know how to decalcify the Starbucks Saeco Italia Digital Barista Fully Automatic Espresso Machine.
Posted on Apr 01, 2010
skistockli
  • 73 Answers
SOURCE: Need manual for Wal Mart GE Brand Coffee Station
Here is a link: http://ww2.justanswer.com/uploads/Techy2000/2009-09-24_150738_169069_Coffee_Station_IM_English_1149277158838.pdf
Posted on May 28, 2010
The water is cold in a cofee
Has the heating element become defective ? Check this first. Replace
You will need the make and model of your coffee machine and probably the service manual and a new element of the correct type and tools for the job. Otherwise you have to get it repaired 'professionally'
15.January.2015
Jan 15, 2015 | Coffee Makers & Espresso Machines
Fault on Siemens TK76K573, after pump replacement
The water passages in the espresso makes may be clogged. Please descale the machine. Depending on the period for which the descaling was not done, it may need nore than one descaling cycle to remove accumulated Calcium deposits.
Calcium deposits narrow water passages and reduce the pump pressure to push water through the coffee grounds.
Oct 18, 2014 | Coffee Makers & Espresso Machines
Siemens coffee maker model tk540001 brewing unit is stuck!
Hi, I am a user with the same problem but on a Siemens TK580001. Is the solution applicable 1:1 as the two models have different panels?
Jun 11, 2012 | Coffee Makers & Espresso Machines
Looking for repair or service manual for Jura E80 auto coffee maker.
Hi Glen
MANUALS & Instruction Books are On Line
The drivers & Books & manuals are more than likely on the manufacturers site.
They usually can be downloaded for currently available devices.
Search their support area for your specific model of device.
Try Google Search for a Manual or PDF File for the specific brand & model number.
Also check these Sites:
www.retrevo.com .... Manuals
www.office.manualsonline.com
Feb 01, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
SIEMENS TK 68 E FILL UP PIPE SYS MESSAGE ON SCREEN
Mar 06, 2011 | Coffee Makers & Espresso Machines
Need service. one wond doesnt work. it brews too fast espresso is bitter. having a hard time finding a repair service in auburn, alabama. can u help?
I might be able to help you repair it. First I need the model of the machine is it a DUE/A or a Special 87. Next check the steam wand tip to make sure it is not blocked, if not blocked, you might have to remove the top panel, if it is a due there are 8 screws on the top if it is a special 87 there might only be 4 or a series of panels. Turn off machine and disconnect from power. Then follow pipe from steam valve to boiler, remove the pipe you will notice blockage either in the pipe or at the boiler fitting, clear blockage. For the group heads I would check the screens make sure there is no damage, and check the grind on the coffee grinder that might be too coarse.
Aug 23, 2010 | Faema FA60081
I purchased the espresso maker above. My problem is the strength of the espresso brewed. It comes out strong at first, but by the end of the dripping it turns watery. By the time the dripping stops the...
to have a good espresso depends from many factors, first of all is the coffe blend, the grind, then water quality, espresso maker pressure and temperature, and that is just the most important!...I think you can try with a REAL espresso blend with very thin grind, let the water flow without filter, then when the light switch on put the filter, you can also try to warm first for steam and after commute to make espresso and wait for right temperature. Finally you will obtain a discreete espresso, never as in the professional machines!...otherwise you have to invest such 2000 euros for a professional good coffe machine
Aug 22, 2010 | Ariete Cafe Retro Espresso Machine
The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Jul 20, 2010 | DeLonghi EAM3400 Espresso Machine
Where can i get my saeco vienna machine repaired in Houston TX
Purple Turtle Coffee
211 W, Main St
La Porte, TX 77571
281 470 6555
I just picked up my repaired Saeco expresso machine. The people that work here are very professional and spent a lot of time with me showing me how to properly clean my machine. It was about a 30 minute drive east from my house near the Galleria but it was WELL worth it. I say that as I sip on some homemade Latte - yummy!
Nov 10, 2008 | Saeco Vienna SuperAutomatica Coffee...
I need francis X1 repair parts
The sole UK importer who are based in Northampton steer all "domestic" type servicing / repairs to www.coffeetech.co.uk who offer a repair service.
Sep 23, 2008 | FrancisFrancis! X1 - Stainless Steel...
Coffee Makers & Espresso Machines Logo
60 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
