Question about Dishwashers
Can you connect a dishlex global 300 dishwasher to the hot water supply?
Hi Devilnz_05
I have a DX300WA global model and the instruction manual actually recommends that you use the hot water outlet for a better cleaning result, but of course it is not mandatory.
Posted on Jul 06, 2010
2 Suggested Answers
  • 713 Answers
SOURCE: dishlex global 300 : dishwasher dispenser won't
Hi just read your posting.The problem could be a faulty dispenser coil ,or the wires to it are faulty or the computer is faulty.Try selecting a normal eco wash and when you push the start button to start the machine hold the button in until the pre wash light turns off.This should make the dispenser activate straight after it fills.The only way to test which part is faulty is with an electrical meter.Have you or can you borrow one.If so then I can guide you step by step in finding the fault.please reply with additional information and I am sure I can help you further.Looking forward to your reply.
Posted on May 22, 2011
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Dishlex Global 200 won't fill with water
Shut off the water to the dishwasher. Take the line off where it connect to the dishwasher. Get out a bucket (dishpan, etc.) and put the open line into the bucket, turn on the water. Does it have a good stream? If not the problem is in the supply coming from your house. If the stream is good, house water is fine. Connect the supply back up, find the electrical solenoid that the water feed goes to and disconnect the line on the other side of it. Try turning the dishwasher on with bucket catching water, when the solenoid clicks on is there a good stream of water? If not either solenoid is bad, or maybe there is a filter (screen) before the solenoid that needs cleaned. If there is a good stream after the solenoid, then the controls must be bad telling it to shut off too early.
Dec 25, 2011 | Dishwashers
Have a Dishlex Global 500. Can this be connected to cold water only & if so do we just not connect the hot water hose? Thanks, Kyle
yea, don't connect the hot water, but if it has an automatic hot cycle, you will have to hook up the hot WATER
May 01, 2011 | Dishwashers
Dishlex global 300 just installed new pump now wont fill up just stuck on drain
make sure you have the hoses attached to the water supply usually hot water under your sink.
Jul 06, 2010 | Dishwashers
Wanting a maunal for Dishlex 300 global dishwasher. Model DX 300 WA * 01. Thanks
Try this site. www.appliancehelponline.com Just supply your model or product number.
Hope this helps.
Jun 07, 2010 | Electrolux Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Not disolving powder thru cycle
This may be a problem with the powder that you are using. It may also be a problem with the temperature of the water that is coming into your machine (not hot enough).
You may want to try a gel type detergent.
If you need more help, post a comment.
Thanks,
Tim
May 29, 2009 | Electrolux Dishwashers
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwashers Logo
358 people viewed this question
Top Dishwashers Experts
