Question about Primera Technology LX400 Color Label Printer (P/N 74261)
My LX400 was printing correctly on the labels and now it has gone haywire, printing correctly on some labels and then off to the side on others. I have recalibrated the printer several times, which fixes it for a couple of prints and then it starts printing off to the side again. HELP!! I am going crazy trying to print out the labels that I need by tonight.
  • Anonymous Mar 24, 2014
    we changed the roll of labels and now it won't print
    Genius:
  • 1,478 Answers
First, the fuser assembly may be damaged or at the end of its life. The solution is to replace the fuser assembly. Repairing a fuser assembly is generally not recommended because the fuser is considered a consumable printer part and not worth the time or effort to fix. Second, the toner cartridge may be defective and letting too much toner out at one time. in this case, you will need to replace it.
Take care.
Posted on Aug 22, 2010
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
Hi I am trying to print labels. Avery #05161 and business cards Avery8371TM or 5371TM. I am using Microsoft Office and there do not seem to be any relevant numbers. I have gone under labels. Help Thanks
You can use a different template for either the labels or the business cards, just make sure the labels you choose are the same size as the avery 05161 & the business cards are the same paper eg: glossy etc. The other thing you can do is go to avery.com & download the correct templates.
I hope this helps you
Jan 21, 2011 | Avery Address Labels AVE4151
How do I feed an AVERY label 5453 into the printer?
Just place the sheet of labels in the paper tray.
You may need to place the labels face down in the paper tray so the prints on the correct side of the labels. If it didn't print on the correct side of the labels then place the labels face up.
Jan 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Loaded ribbon correctly according to Zebra S4M Quick Reference guide....but won't print anything on labels.
The ribbon has wax just on one side. So, if nothing prints on the label, first thing I'd check if the ribbon loaded with waxed side facing label.
Jan 11, 2011 | Zebra S4M Thermal Label Printer
My new hp 2035n printer give an error when i try to print. the error says: load paper to tray 1
Instructions Things You'll Need:
  • Inkjet printer
  • Labels
  1. 1
    Prepare your printer. Make sure the power is on and the drivers are installed correctly on your computer.
  2. 2
    Wait for printer to stop. Make sure your printer is idle or ready or waiting for paper to be loaded. Don't load labels when your printer is already printing or running an operation.
  3. 3
    Prepare your labels. Make sure they are all facing the same way and are right side up. The label side should be face up. Many labels have an up and a down as well, look for a "this side up" or "load this way" indicator. Or take a look at the print preview before you print and make sure your labels will be fed correctly.
  4. 4
    Find the correct paper tray. Some printers have manual feeds and automatic feeds. Refer to your manual to find out which one you should use for labels. If you are going to use the manual feed, follow the manual's instructions. However, most printers will use the automatic feed, so read on.
  5. 5
    Align the paper guide. This is a moveable piece on the paper tray. There should be markers for the width of your paper. Standard pages are 8.5 inches. Move the marker so your labels will fit.
  6. 6
    Load your labels. Place your labels in the tray so it touches the immoveable side of the paper guide. Slide the paper guide over to touch the other side if it is not already close. Do not bend the labels by pushing in too far.
  7. 7
    Find the paper thickness lever. Try looking under the door that lets you change the cartridges. Or search around on the back or side. Check your manual, too.
  8. 8
    Set your paper thickness level. Usually you'll use the standard size. However, your printer may need to use a thicker setting. Check your manual.
  9. 9
    Change your media type. In your printer settings, find the media type option. You can access settings by clicking properties or settings on the print dialog right before you print. Select "labels."
Oct 02, 2010 | HP P2035N LaserJet Monochrome Printer
Cannot print multiple copies
Is the printer set for label taken, if it is then it is waiting for the sensor to see the label is gone before printing the next one. Apart from that, check the settings in the driver and make sure it is all set correctly
Feb 09, 2010 | Zebra Z4Mplus Label Printer
Polyester labels from tray 1 4 labels per sheet right side color
It says on the website the labels are 56lb (I guess cover weight). The only way the stock will run right (ie) fuse correctly is in the mp tray using one of the thicker settings. Also if you run labels out of the tray you run the risk of them peeling off making the turn out of the tray and into the machine. All non standard paper is better off using the mp tray.
Mar 29, 2009 | OKI C5150n Led Printer
Primera Technology LX400 Color Label Printer (P/N 74261) Logo
176 people viewed this question
Top Primera Technology Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
