Question about Garden
Cant find replacement bar for SKIL chain saw model #947 typ 4 ser# 078815. old bar#71913 PQ 91
  • 211 Answers
SOURCE: interchange smaller bar & chain for existing chain saw
Yes you can(better for the engine).For14" the part number is 52 and for 16" is 60.
savumihai71
Posted on Nov 29, 2008
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
shadtremonky
  • 353 Answers
SOURCE: bar chain oil leaking into case when not in use
if you store it somewhere other than a climate controlled building , the changes in temperature can cause the oil to expand out of the saw a little each time the temp. goes up.
try some absorbent cloth
Posted on Jun 21, 2009
dontbother10
  • 2220 Answers
SOURCE: Chain keeps falling off bar afterwhen saw is
Reinstall the chain. Do NOT connect power. Mark one link (chalk, crayon, etc.) wear gloves and try to rotate the chain one complete revolution. Is this possible? No - remove the chain and remove burrs from the sides of the drive links with a flat file.
3893c9d.jpg An IPL for your saw can be found here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Enter "111409" in the "Search for your unit by Model #:" window. Click search. Click "View Model" Click "View Illustrated Parts Diagram"
Yes - inspect the sprocket gear (KEY NO. - 11) pn 111363-01 new pn 122520-01 NLA, is it deeply grooved or perhaps worn through?
I'm going to get smacked as I have so many times before. The only thing RemingtonPower is producing today is unhappy customers. Replacement parts are exhausted. we aren't affiliated and had nothing to do with their decision to stop production.
Burrs on the chain or a defective sprocket are the most likely causes of your problem. If the gear is bad, there are no replacement parts available and I cannot help you further except to recommend you purchase a name brand replacement. Select a company you think will have replacement parts when you need them sometime in the future.
Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
Your rating of our help is the only payment we get for this service. I provided as much help as humanly possible. Punishing me for your disappointment with RemingtonPower isn't fair to me. I hope I answered your question. Thanks. A few kind words would be appreciated.
Lou
Posted on Nov 02, 2009
VtToolMan
  • 704 Answers
SOURCE: I have a MAC 3516 and need a replacement bar and
Hello Eric, You can get an Oregon brand bar and chain that will work perfectly on your Mac 3516. I have this same chainsaw and keep a spare bar and chain, so I can quickly swap them out, should they get damaged, etc.
The Oregon bar and chain part numbers are as follows:
#100457 (Bar & chain combo pack)
You can also find these sold at most Home Depot, Lowe's and other hardware stores that carry chainsaws, as Oregon makes their replacement bar and chains to fit all the major brands available.
Unless your existing bar and chain are completely galled up, scored or bent/busted beyond repair, I would find a small engine repair shop or local hardware store that sharpens chainsaw cutting chains, (True Value and Ace do it in our area) and see if they can sharpen and true up the bar. The price for this is typically about 1/3 to 1/2 the price of a new chain and bar set, and worth having a spare around.
I also like having that extra aleady to use (sharp) chain, so when a neighbor borrows my saw and invariably lets the chainsaw go into the dirt (that'll dull the chain so fast!). I will always be able to use my saw, when I need to, without having to run out and get a replacement, or spend 15 minutes having to sharpen it by hand, etc.
I hope you find this Very Helpful and best regards!
Posted on Nov 24, 2009
Testimonial: "I cannot believe the fast and accurate responce to my question, thanks for your help it is greatly appriciated"
An earley 1984 husky 34 delux chainsaw bar has 320855 plus the number 120 under it
The Husky 34 was a badge engineered machine, it was actually manufactured by Skil under licence, it ran a 3/8 low profile chain ( 91sg ) 050 gauge, sorry cant remember the drive link count,after market bars and chains are still available from Oregon ( Blount ) it has to said it was not the best hobby saw going.
Jan 23, 2011 | Garden
Cant put trigger back togather
generally they are not disassembled, I would recommend replacing the switch, you can find one at any local repair facility, just take the old one in and they should be able to match it up.
Mar 30, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
How much lubricant do I need to replace all of the lubricant in my old skil 77 7 and 1/4 " saw?
Put saw on level surface than fill till you see the oil come up to the threads. Do not let it hit the threads or it is over full.
Jan 11, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Describe your Skil 7 1/4" Magnesium
You have large plastic screw on the saw, remove it and fill the oil to bottom of threads and that should be it.
Sep 15, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I have a very old Skil circular saw Model #586. What size blade does it use?
measure from the center of the shaft to the inside of the guard, double that distance. subtract about 3/4 of an inch and this will be real close to the blade diameter that you need
Aug 16, 2009 | Skil Saws
Remington 16 in. electric chain saw
Go to www.masterparts.net Remington chain saws are listed by bar length and model number. There is a parts list with each saw.
Oct 27, 2008 | Remington Electric Chain Saw
14 inch electric chain saw throws chain off
If a new chain ::
make and model is important here, as are guide bar length
a particular chainsaw, may be available with 12,14,16,18,20,22,24,26 inch guide bar,
likewise different saws (even from different makers) use the same size of chain
a chain for this saw may be sold in a variety of lengths or
may be sold in the longest length only and require links removed to suit smaller bars.
back to the store, with the saw, for confirmation
If an old chain::
stretched way beyond safety, replace
Sep 27, 2008 | Remington Electric Chain Saw
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
