Question about Ovens
The oven doon wont unlock and theirs a humming sound comeing from the oven I set it to clesn and waited untill it was done 2 times but it wont unlock .. I unpluged it and waited a hour then pluged it back in but same still does not unlock . any clue I have been looking for info on this but not finding my model # JGSP30GEP2BG and yes I check the number 3 times. any clue thanks Neil achadnow@msn.com and at Tazz1122@aol.com thsnk you
  • Ovens Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Aug 22, 2010
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
How do I set this clock on a gas ilve stove
Ok most of them have a button or there are some modles that it looks like small rubber tabs you have to use a ink pen for them It will be 2 buttons top and bottom push the top in and wait till it flashes on the hour bottom changes time then re push the top button until min comes up and set with bottom button Your done
Mar 31, 2013 | Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
I used self cleaning and when it finished now the oven wont come on did cleaning again and still oven wont come on door just appears in the display window.
You generally have to wait for the unit to cool down before the door will unlock. If you waited both times for more than an hour then during the selfclean cycle the control board was porbably damaged. Try shutting the unit off at the breakerbox for your home and wait 1 to 3 minutes.
Sep 01, 2011 | Ovens
We had a power cut, now I can't get the oven to work the auto light is flashing but when I turn the knob for the oven it won't come on.
You need to reset the oven from auto to manual setting.
This is done by pressing 2 or more buttons on the timer at the same time to reset it, until you do this, the oven will not work
Feb 17, 2011 | Tecnik TKC8085 Electric Double Oven
Used the self cleaning cycle 24 hrs. ago, but the oven door will not unlock. We tried to run it through another clean cycle but we recieve an E1 error.
Sorry to read about your problem, I hope this helps you out.
you may have done a panel lock, so try the first solution.
To Lock/Unlock Control: Before locking, make sure the ovens, Timer and Timed Cooking are off. Press and hold START/ENTER until a single tone sounds and "Loc," a picture of a lock and "START?" will appear on the oven display, about 5 seconds. Repeat to unlock and remove "Loc" from display.
To Stop Self-Clean any time:
Press UPPER OFF, LOWER OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Whirlpool RBD245PDS Electric Double Oven
F 2 error message when cleaning
Your oven sensor may have died during clean. turn off power open controle pannel , there should be a tech sheet(paper diagram and instructions for service guy) inside. it will have the codes on it as far as what they mean. It should point you to what part to change.
Nov 03, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Oven won't turn off or unlock after cleaning
Very likely you did not wait long enough for the oven to cool. Once it cools enough, it should open. Hope this helps!
Jan 01, 2009 | Frigidaire Ovens
I have a self-cleaning oven and set it to clean for 1 1/2 hours. The light turned off at the end of the time but the "sound" made during cleaning didn't stop. When I followed the procedures of turning the...
how long did you wait to open after cleaning, it won't let you open till it is cooled down to a safe temp. if its been several hours then the high limit t stat may have opened and you need service. prideapplianceser@sti.net
Jan 01, 2009 | Ovens
Oven won't unlock!
find the circuit breaker panel and turn off the one labeled "oven". wait 30 minutes and restart. any luck?
Jun 01, 2007 | Kenmore 42161 / 42169 Electric Single Oven
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
