Manual for whirlpool washing machine wfs1071bw
Richie_asg1
  • 1036 Answers
SOURCE: WHIRLPOOL WASHING MACHINE
From Whirlpool direct, you can download the users manual - Here
Just enter the model number and you should get it.
Alternatively, phone the number on their site for a copy to be posted to you.
Posted on Jun 20, 2008
Jahn27
  • 1554 Answers
SOURCE: Hi, I have a whirlpool WFS1071BW
The pump is located behind the front bottom access panel. Remove the said panel and you'll see the pump assembly with the pump filter on it. Place a shallow pan or lay a piece of towel under the pump assembly to catch residual water from the pump then turn the filter knob counterclockwise to remove it. Also turn the pump impeller to check for any debris or restriction. Make sure the drain hose is not clogged or kinked. You may need to replace the pump if cleaning the filter, the impeller and the drain hose do not address the flashing of the clean pump indicator or if the impeller is restricted.
Posted on Oct 03, 2010
SOURCE: Whirlpool WFS1071BW front load washing machine -
Unplug your washing machine and then you will be able to get the door open and the clothes out. You may need to leave it off for awhile to get it to work but make sure you have a bucket ready to catch the water coming out.
Posted on Oct 19, 2010
  • 2699 Answers
SOURCE: I have a whirlpool WFS1071BW & the bowl
sounds like you broke the motor coupling,also the model number you sent doesn't come up.remove the two screws that hold the top console down,flip up the console,remove the two metal clips and unplug the harness closest to the right clip.open the lid,grab the frame tilt it up and back and the whole frame can be removed.look at the bottom,remove the two clips and slide the pump off,do the same to the motor and on the back you'll find the motor coupling.most likely it will be broke.remove the other half off of the tranny.install the new coupling and you should be fine.if you need anymore help let me know
Posted on Jan 23, 2011
allbrands
  • 600 Answers
SOURCE: The red light 'Clean Pump'
the small cover trim across the bottom front of the washer comes off. under it is your pump clean out it is a cap you twist off to clean out the pump. have a towel ready water will come out. hope this helps and please rate me thank you...
Posted on Jun 06, 2011
Testimonial: "Your description was accurate. Simple job when one knows what to do. Thank you very much."
My Whirlpool WFS1071BW goes through the whole washing cycle but doesn't stop at the end of the last spin cycle, just keeps spinning for hours. Anyone have ideas why?
We're very sorry to learn of your concerns regarding your Whirlpool® Washer. We would like to inquire further about your review with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your Reviewer ID, the name of the site you were contacted on (fixya.com), name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance. Please include a brief description of your concerns in your email. Thank you.
Sep 11, 2017 | Whirlpool Washing Machines
How do i fix a Whirlpool wfs1071bw which has just suddenly stopped working after 5 weeks of being idle? was perfectly fine before i went on holidays!
No, it is not common to fail in that way. I suggest that you check the breakers to make sure that they weren't shut off while you were away. I hope that is all that is wrong. There is always the possibility that there was a power surge that damaged the machine, but I've never seen that happen to a device that was not on, and I would think that other electronic devices would also be damaged. I hope this helped. Dan
Jan 10, 2016 | Whirlpool Washing Machines
My WHirlpool WFS1071BW when turned on keep tripping the fuse.
probably motor short or pump motor short washing machine service man or lady is required
Sep 27, 2014 | Washing Machines
Whirlpool Front Loader WFS1071BW, rinse cycle problem
I had exactly the same problem with the same machine... I've seen a few people on various forums with the same problem. The problem on mine turned out to be just the EMI filter located next to the power cord inlet. I just bypassed it for now until I can get a replacement.
Apr 26, 2013 | Washing Machines
Whirlpool front loader washer model: WFS1071BW I have broken the knob/dial that controls all the functions. The one in the front, it looks like its snapped off from somewhere inside (the blue piece is...
Hello, Thank You for using FixYa. I will be helping you today.I believe you have to replace the whole user interface. Here is the diagram i dont see just the shaft. http://lookup.bellparts.com/diagramenlarge/whirlpool/4292/00061361
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The red light 'Clean Pump' on my WFS1071BW washing machine is on. How can I access and clean the pump? Thank you for your response.
Jun 06, 2011 | Whirlpool AWM5125/1 Front Load Washer
I have a WFS1071BW and the"clean pump"light keeps coming on. What do I do?
remove the 2 screws by the floor,then remove the cover below the door,there is a clean out cover to remove to let you clean it out,have a pan ready because it will make a mess and a stinky one at that
Oct 14, 2010 | Whirlpool WFW8300SW
May 10, 2010 | Whirlpool Washing Machines
Front seal on whirlpool front loader (WFS1071AW)has torn and now leaks from front where can a replacement part be sourced
ck with whirlpool dealer or sears parts..sears.com has a parts look up system allowing part lookup for all national brands
Aug 09, 2008 | Whirlpool Washing Machines
Washing Machines Logo
1,007 people viewed this question
Top Washing Machines Experts
