Question about Midland 1001Z 40-Channels Base CB Radio
Modultion less than 30 percent.,some one said,,rv201,,but thats hear say,,want to be sure,,
    Genius:
  • 1,274 Answers
Hi, you will have to put it on a modulation meter to tell for sure, turn your mic. gain to max and see what happens....hope this was helpful....
Posted on Sep 02, 2010
How to turn up the power on the midland 78 plus
Midland 78-574: {L209, L212, L214, RV9-AMC, RV201-ALC, RV#-SSB MIKE GAIN, VR4-AM PWR}
Midland 78-976: {L7, L11, L13, RV12-AMC, RV2-ALC, RV11-SSB MIKE GAIN, VR4-AM PWR}
Midland 78-999: {L209, L212, L214, RV9-AMC, RV201-ALC, RV#-SSB MIKE GAIN, VR4-AM PWR}
I put these up due to not knowing which one you have
May 07, 2015 | Midland Radio Communications
Tub capacity of maytag performa
It holds 3.9 cu feet. According to Maytag "This 3.9 cu. ft. capacity high-efficiency washer also features the MaxExtract™ option, which spins clothes at up to 1,300 RPM and means less time doing laundry. You get all that and still use 79 percent less water and 76 percent less energy". A cubic foot is the volume of a cube whose sides are all 1 foot long.
Feb 13, 2015 | Maytag Performa LAT2500A
How do you find a total number of a percent in a word problem
Divide 100 by 40. You get 2.5. Now, multiply 30 by 2.5. You get 75, which is the percent of distributed flyers.
Jan 02, 2015 | Office Equipment & Supplies
I raised $948,963 last year. I raise $ 817,430 this year. Is that 9% less raised this year>
No.
You can divide this years by last year and that gives you the percent you got this year compared to last. You raised about 86 percent of what you raised last year. so 100 percent minus 86 percent. That is equal to 14 percent. You raised 14 percent less this year.
Jun 14, 2011 | Office Equipment & Supplies
Internet connection slow, how do I speed up my service.
Have you tested your service and compared the readings based on the service you are paying for? You should test with a direct connection (no router) to your PC and then test again with the router in place. Try www.speedtest.net as a test site. You can also try www.speakeasy.net as another test site with a little less graphics load. If your bandwidth is less than advertised (expect the actual to be about 25-30 percent under the advertised) then contact your service provider to see if they offer faster service
Apr 16, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Getting humidity to 30 percent
A refrigeration type dehumidifier will not go much below 40%, just can't get the water to condensate below that at normal temperatures...
You will need to use a desiccant type unit to go to 30%..
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 11, 2010 | Whirlpool AD35USS Dehumidifier
My new Bosch Nexxt 500 series washer is less than 30 days old. I can turn it on any program and I can hear it initially fill with water, but it does not spin to wash or rinse. It does not have any error...
As your washer is less than 30 days old, I strongly recommend that you contact the company you purchased it from, and ask them to change it for you, under the sale of goods act, you have the right to insist upon a replacement washer.
However, before you do that, double check your handbook, and make sure it is nothing you have done wrong.
Try switching it off, and then try again to use it.
Please leave feedback.
Thankyou
Nov 13, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
CHECK ENGINE LIGHT ON CODE P0170
DTC P0170 applies to fuel trim malfunction on all 2.4L vehicles, 3.0L Federal vehicles and right bank (bank 1) on 3.0L California vehicles.
DTC P0173 applies to fuel trim malfunction on left bank (bank 2) on 3.0L California vehicles.
DTC Set Criteria (2.4L)
Engine is in closed loop control. Intake air temperature is more than 14°F (-10°C). Barometric pressure is more than 11 psi (76 kPa). Volume Airflow (VAF) sensor output frequency is 88 Hz or more. Code will set if long-range fuel correction is less than -12.5 percent, or more than +12.5 percent, for 5 seconds and short-range fuel correction is less than -10 percent, or more than +10 percent, for 5 seconds.
Engine is in closed loop control. Intake air temperature is more than 14°F (-10°C). Barometric pressure is more than 11 psi (76 kPa). VAF sensor output frequency is less than 88 Hz. Code will set if long-range fuel correction is less than -12.5 percent, or more than +12.5 percent, for 5 seconds. On 2.4L code will also set if short-range fuel correction is less than -15 percent, or more than +15 percent, for 5 seconds. On 3.0L Federal code will also set if short-range fuel correction is less than -13.5 percent, or more than +13.5 percent, for 5 seconds.
Have the O2 Sensor changed on the Right Bank, ( passenger side of the Engine, or where the # 1 cylinder is.)
Good luck and hope this helps
May 02, 2009 | 1997 Mitsubishi Mirage
Midland 1001Z 40-Channels Base CB Radio Logo
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
