Question about Vacuums
I just got a coralife SPL-165R-JS replacement ballast for my saltwater aquarium but not sure how to hook up the output pins to the wires that go to the bulb. It says pin 1&2 - fila1 and pin 3&4 - fila2, what the heck does that mean? I can't find any wiring diagrams anywhere.
reddevil6
  • 1673 Answers
SOURCE: Wiring diagram
Check the cord to make sure you have continunity throw both leads, check them at the cord reel, there are 2 wires hooked up to it, if not then the cord is bad. Check the swith also, the next cause would be the speen control mounted on the motor, part #04416342, sells for around $85. If your motor checks ok, then it most likely the speed control, they go out quite often.
Posted on Jan 17, 2008
battlesmith
  • 382 Answers
First check the cord to make sure you have continunity throw both leads, check them at the cord reel, there are 2 wires hooked up to it, if not then the cord is bad. Check the swith also, the next cause would be the speen control mounted on the motor, part #04416342, sells for around $85. If your motor checks ok, then it most likely the speed control, they go out quite often...Thank you
Regards!!!...
Posted on Jul 24, 2008
  • 157 Answers
SOURCE: Replaced Oreck power switch. 2
Both black go to the switch. Power in - black to switch / white to white from motor.
From motor - black to switch / white to white from power cord
The black wire from the power hooks to the off end of the switch and the black wire from the motor hooks to the on end. Third post is not used. The two white wires are connected to each other with a small twist on wire nut.
Posted on Nov 03, 2010
Testimonial: "I think Oreck used the white connector on the lighted switch for power. I must have tripped the breaker a dozen times with a short."
  • 694 Answers
SOURCE: where can I purchase a
Any Aerus Electrolux store should have them in stock.
You can find the one nearest you by following the directions on the below site:
http://www.aerushome.com/storelocator/
Posted on Nov 16, 2010
aquaman987
  • 927 Answers
SOURCE: I am tiring to install
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Posted on Apr 19, 2011
In reinstalling the cord winder I got a little aggressive I disconnecting the wiring, like all of it. No problem just use my cheat sheet that I now realized it's gone. Help ! I don't want to blow som
Well, I presume that you have two colors. Or perhaps three.
I am not familiar with your model, but Green is always ground, all whites go together.
That leaves black. Black it the hot wire, and wants to go to the switch FIRST. Then other blacks hook up to the output of the switch.
If you have twist wire connections, be sure to trim up and re twist. leaving no single strand out. Nice and tight.
Doc
Dec 12, 2014 | Miele S514 Solaris Bagged Canister Vacuum
Wiring diagram
Regards!!!...
Jul 24, 2008 | Miele Cat & Dog 326i Bagged Canister...
Can't hook up power cord to main motor on Hoover model F5915100
You have a black and white and green wire. Green is ground white is neutral, black is hot . Should say on the motor either L1 = black wire. L2 = white wire , G = Green wire or it say H = black wire, N = white wire , G or the symbol for ground = green wire
Apr 11, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Shop vac blowing instead of vacuuming
Most Shop Vacs allow you to hook the hose up to the output valve as well as the intake.
Make sure that your hose is hooked up to the intake valve on your shop vac.
Nov 16, 2011 | Vacuums
Kenmore upright Model 116 31912101 Brush doesn't turn. Little red reset pin doesn't move.
Something is jammed in it or the belt is bad.Turn it upside down.You will see 4-6 screws.Remove the screws and the plate they are holding.Now the brush is exposed.The belt hooks on to the brush and a small wheel on the other end.Remove the brush and belt.Make sure the area is free of debris.While you have it off,replace the belt.
May 16, 2011 | Kenmore 31913 Progressive Direct Drive...
How do i charge my i stubble 7890u it came with 2 pin plug i changed it to a 3 pin plug but it keeps blowing the socket
It sounds like you have a stray wire shorting in the 'new' 3-wire plug..
Or some other form of mis-wiring--
Look at the plug, and make sure that your 2 wires are connected only to the 2 spade shaped plug blades--- NOT to the Ground plug.
May I ask-- why you converted to the 3 wire plug?
The 2 wire plug worked in the 2-wire plus ground receptacles, OK, didn't it?
Mack B
Dec 28, 2010 | Vacuums
When i put hose in port it will not turn on...all the other ports work except one
Open the door on the inlet port and look inside. You should see 2 small pins. These pins are spring loaded to make contact with the metal end of your hose when you plug it in. Two low voltage wires are screwed to the underside of these pins. The low voltage wires go all the way back to the low voltage switch/relay on your central vac power unit.
Sometimes one or both of these pins will just break so that they don't make contact with the end of your hose. If you see no pins or just one then you will have to replace the inlet cover.
If both pins are present; push down on them with your finger. If you feel resistance then your inlet is probably OK.
CAUTION: IF YOUR CENTRAL VAC INLETS HAVE A 110 VOLT CONNECTION, REMOVAL/REPLACEMENT OF YOUR INLET SHOULD ONLY BE DONE BY A QUALIFIED ELECTRICIAN.
Remove the two screws in the faceplate. Carefully slide the inlet cover out. Check the two screw on wiring connections. Make sure both wires are securely attached and that there are no breaks.
If neither of the above fixed your problem, you may have a broken or disconnected wire somewhere between this inlet and the low voltage witch at your power unit.
May 04, 2010 | Broan-NuTone CV353 Central Vacuum
My dyson will not switch on , the last time I used it the power faded in and out a couple of times I wiggled the lead and it continued to work. However today it will not power up, I have changed the fuse...
hi from uk the symptoms you described is a classic fault with where power wire has broken within the main cable usually at pint where it enters the vac ? hence wriggling wire temporarily makes contact are you sure the wires in plug are connected into their pins securely ? constant pulling on wire whilst vacuuming does cause this fault also kinking in wire you can diy replace the whole cable and replace with longer length as i usually advise so you can reach further without having to swap sockets ? hope this helps/inspires you ?
Dec 05, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
G4 plug
Does not matter much. Any will do.
Oct 24, 2008 | Kirby G4 Bagged Upright Vacuum
Wiring diagram
Jan 17, 2008 | Miele Cat & Dog 326i Bagged Canister...
Vacuums Logo
67 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
