Question about Jacuzzi Impeller, L - 3/4 H.P
How to separate the two impeller flanges of a jacuzzi pump to access the impeller in order to remove the wet end from the motor OR is there some way to remove the wet end of a white JWB 60C Ser no. 06785 jacuzzi pump that is attached to a Gould 1 HP motor - the flanges seemed solvent welded (removing the five bolts do not separate the flanges) and the discharge end of the pump has a coupling glued on to it, thus I can't take the pump off and it LEAKS!
  • drfitch141 Aug 27, 2010
    OK, seems the replacement pump above is three times as expensive as other available wet ends (maybe the brand name thing) - if I wanted to get out of the Jacuzzi pump business, are there other pumps that can work with my motor (which is in great shape) - Gould 1 HP K56J CS, thanks
    President:
  • Jacuzzi Master
  • 1,378 Answers
That is an old sealed Jacuzzi pump that can not be repaired. It is one of many reasons why Jacuzzi never did well in the pump business and has gone from owner to owner over the years. Unfortunately your pump is not repairable without destroying it in the process.
Wet ends may still be available. The part numbers I have are:
850100 .5/.75 HP
9011000 1 HP
850200 1.5 HP
856600 2 HP
0199000 Gasket (2 req’d)
4516000 Flange, 2”
Good luck,
John
Posted on Aug 27, 2010
How do I break down pool motor aol 1-1/2 hp
It depends which pump you have, on hayward super II you shut off the breaker, remove the rear motor cover, disconnect the electrical wires, then remove the 4 (9/16")bolts holding the motor to the "wet end" which is where the basket is. Now, pop off the diffuser, sometimes it stays in the wet end when you remove the motor. At the rear of the motor, use a 12mm wrench to hold the shaft, then unscrew the impeller (counter-clockwise) after removing the impeller, theres another plastic plate that lifts off, remove the plate, now there are 4 (9/16")bolts to remove in order to separate the motor from the seal plate. You have now broken down the pump. If you replace the motor, make sure to get a new seal as well (ps201)
Feb 12, 2015 | Hayward 1.5hp Pool Pump Motor Motor A O...
How to replace impeller
take bolts out to separate wet end of pump and motor then remove screw if one on impeller sometimes they are backwards threads take screw out then unscrew impeller while holding shaft of motor that should be a regular thread separate backing plate from motor change seals then revese
Jul 06, 2014 | Pool & Spa
How to separate pump from motor
take screws off around housing that separates motor from wet end remove diffuser then remove screw from impeller backwards thread and hold back shaft of motor after removing still hold shaft and turn impeller off regular threads make sure to replace seals
Apr 16, 2013 | Pentair 1 hp WhisperFlo InGround Pool Pump...
Jacuzzi pool pump leaking
Where is it leaking? if it is still leaking between the wet end which is the black plastic water housing and the motor then the seal is not properly set.
Rod
US Parts Center
Aug 04, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
I have the 7-184948-22 1 hp Got home to day (very hot ) motor was triped off. Reset and now it just hums, locked up. Any hope? It's about 3 years old
Turn off the power at the breaker, then reach in to the impeller and see if it will turn freely. If it does you probably only need to replace the capacitor. If it will not turn freely you'll have to remove the motor end by unscrewing the large ring that holds the motor to the wet end. Remove the small screws that hold the diffuser cover and inspect the impeller and impeller ring, sometimes known as an impeller weir or floating eye seal.
Even if you have to replace the motor this pump is worth saving if there is no damage to other components. Note: Replacement motors are easy to find, I favor Magnatek / A. O. Smith motors but any brand such as Emerson or other will do. Jacuzzi parts though are getting increasingly hard to come about.
Jul 21, 2011 | Jacuzzi Magnum Force Series Pool Pump 1...
Need to know how to remove the impeller.
remove back cover of mtr. hold shaft with large screw drver. remember some modles have rev. threads
Dec 08, 2009 | Jacuzzi Impeller, L - 3/4 H.P
I had a water leak at the pump on my hot tub so I removed the motor and pump assy for repair. I removed and disassembled the wet end and determined I needed a new seal and impeller. Here's where the fun...
Here is your owners manual.
You have the correct impeller part number and the seal is a standard replacement part.
Please contact us thru www.arrowpools.net for a quote on the exact price and freight charges. Before freight, your parts would be about $20.
I can not help you with a whole wet end at this time but the parts should be available within a few days time.
Dec 04, 2009 | Home
We are having issues getting the impeller apart on the jacuzzi magnum force pool pump and need some instructions on how to proceed.
I believe the jacuzzi pump impeller has a locking screw directly in the middle of the impeller. You'll have to turn it clockwise to remove it. Then you'll need to remove the cover from the back of the motor using a 1/4" nut driver. Depending on the motor, you should be able to use a 7/16" open end wrench to hold the motor shaft from turning as you turn the impeller counter-clockwise to remove it. Some motors are different, some have a keyed shaft or require a special tool to hold the shaft while the impeller is removed. Hope this helps.
Nov 22, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Removed four bolts,can not get motor off
depending on the pump you have, you'll need to remove the seal plate from the wet end and remove the impeller before you can remove the motor.
Nov 14, 2009 | AO Smith Pool Pump Motor 1HP Square Flange...
Remove impeller
Based on the limited info. For most jacuzzi pumps, you will need to remove the lock ring and pull the pump apart to expose the impeller/diffuser. Next, remove the diffuser to expose the impeller. Depending on what type of motor you have, either remove the cover plate or cover cap to expose the shaft at the rear of the motor. There are three types of shafts, one is slotted so you will need a large screwdriver to hold it in place. One is larger and can be held with a wrench or special shaft tool. One is more internal and has a switch at the end so it has to be held with a 7/16 wrench under the switch midway between the switch and the housing. You may have to remove the capacitor to gain access with the wrench.
There may be a lock screw holding the impeller to the shaft, if so, remove it by turning it clockwise (left hand threads). Then you can remove the impeller by turning it counter-clockwise. They can get stuck on the threads and you may need an impeller wrench or something suitable to give you some mechanical advantage to remove it.
Oct 20, 2009 | Jacuzzi Pool & Spa
Jacuzzi Impeller,  L - 3/4 H.P Logo
456 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
