Question about Goodman CPLE24-1 Air Conditioner
Compressor fan mtr hot, hear it try to energize for approx 2 seconds then stops aproximately 1minute later cycle repeats, removed coil voltage and manually acuated coil did not hear anything trying to energize, voltage 240 across contactor, assume controll power need be present for any fan / compressor function? sounds like fan mtr single phasing, tried to spin manually, no succ.
  • Goodman Master
  • 43,501 Answers
The motor bearings have siezed up and the motor needs to be replaced...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 22, 2010
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
Oct 15, 2017 | GE Refrigerators
Compressor not working after performing maintenance ( vacuuming out condensor coil/ fan/compressor compartment )
If you have a start relay , remove and shake - if you hear anything it is toast. with a cap either use a cap tester or just replace it and cross your fingers.
Mar 30, 2017 | GE Refrigerators
I have a 2001 chrysler sebring 2.7L SFI 6cyl, and I turn my engine on runs fine but then when I turn on the a/c it blows only hot air. i can hear the idling going up and down so i poped the hood and...
Low on freon,or the expansion valve is bad,try adding freon to the system,if the compressor stops cycling,then that is the problem,if this was helpful,please rate,thank you.
Jul 10, 2010 | Chrysler Sebring Cars & Trucks
Picked up used chest freezer...plugged in and briefly clicks...I can hear it energized for about 5 seconds then quits....it then repeats this cycle. It was on its side when delivered
Try to replace the compressor relay (most of the times problem) ,but if still doing the same clicking noise , the problem is in the compressor.
Sep 29, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Acer Aspire 5520 will not boot
Constant power cycling is generally a sign of either bad voltage or overheating. In either case the failsafes in the laptop cause it to reset continually until the problem resolves itself in order to protect the computer from damage.
First thing to try would be to test the power supply with a voltmeter, if you look on the bottom of the adapter the output voltage will be listed as approx 19V. When you, or your tech, tests the voltage is should be within .25 of a volt of the listed output voltage or it is likely the problem. If it is well outside the listed voltage, have it replace and you should be ok.
Second, assuming the voltage is fine would be a heat issue, if one of your fans is dead or if one of the intercoolers isn't making good contact that would cause the unit to overheat and reset. Even an excess of dust in the unit can cause this although you usually see more than two seconds between resets.
To test for heat issues, remove the battery and AC adapter then blast it clean with a can or "Canned Air" or an air compressor with a step down nozzle limited to no more than 20lbs of pressure as more can damage components. When you hit the main fan with pressure it should spin freely and continue spinning for 4-7 seconds after you stop the pressure. If it doesn't spin or stops abruptly the fan is dead and needs replacing.
If these tests both pass but the unit continues reseting it's either an internal voltage problem or one of the intercoolers is loose, either way you should then take it to a pro for a full diagnostic and see what they can find.
Chris
Aug 15, 2009 | Acer LXA3706003 Notebook
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Whirlpool refrigerator
you can try replacing the overload relay mounted onthe side of the compressor ( kit number 4387835) sounds like its gone bad, trying to start yor compressor, but tripping off on overload.
Jan 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No heat , out door unit doesn't run?
turn fan switch at stat to on . does fan run? it should within 2 to 3 minutes if not sooner. if it does then you know you have low voltage and high voltage a blower and electronic brain . go outside and see of you hear a hum like a faint buzz. that is the contactor being closed and energized. check to see if outdoor disconnect has power ,usually 220 volts and then remove service panel and see if 220 volts arrives at contactor. see if spring loaded contactor points are pulled in and check to see if voltage is feeding through contactor . this will be hot! be sure you know how to use a meter and work live power. if contactor is not pulled in then you have a control voltage problem and you have to get 24 volts from stat to indoor blower to outdoor condensor. with and insulated screwdriver you can simply mash in on the contactor points and fan and compressor should run . only do this for a second or two, but it does simply say hey contactors open, ive got power and it will run but no controll volytage.IF ITS A RUUD OR A RHEEM SOME OF THEM HAVE A RESET BUTTON DOWN WHERE THE REF LINES GO IN . MASH IT IN AND IT MAY RESET, THEYTRIP OFF HIGH PRESSURE, DIRTY FILTER OR COIL IN HEAT OR A BAD FAN MOTOR OUTSIDE IN COOL.
Oct 09, 2008 | Goodman Heating & Cooling
Problem has returned to Maytag fridge
I note this is a very old post. The compressor is not starting and what you were hearing was the PTC relay energizing followed by the KilXon thermal overload kicking off the compressor start sequence. What happens is that the PTC relays sometimes get a heated contact. Due to the weakened state of the contact it can cause a buzz. Even with a goo PTC relay you would hear the compressor buzz if it was not starting. In that case the run capacitor may have failed or the compresor rotor is internally locked at which point the start cycle will repeat every 3 to 4 minutes as the thermal overload cycles and the compressor will not start.
Thanks for choosing FixYa
Kelly
Jun 18, 2008 | Refrigerators
Heating & Cooling Logo
80 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
