I recently had ETSA install a new power service. The YA4928 electronic meter has a " boost button" for the hot water J tariff. When pressed, the meter reads " boost 1..boost 2.,does this mean boost for 1 hour, 2 hours ? Is there a web site instuction manual available?
ginko
  • 19396 Answers
SOURCE: Owners manual for Rinnai Waterless Hot water heater R85?
Here is the manual : Operation / Installation Manual
Posted on Oct 25, 2008
  • 919 Answers
SOURCE: I have new olympus 850SW
To access the panorama mode in the camera you need to be in P mode.
To set the P mode you need to press the Ok button right arrow to P for Program Auto and press Ok. Then as long as you are using an Olympus xD card you should be able to go to menu and highlight the Panorama option.
Posted on Dec 12, 2008
SOURCE: No Manual?
Online Manual (PDF) For DW9116
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/630429-00,DW9116.pdf
Dewalt DW9116 Product Recall:
http://www.dewalt.com/us/articles/article.asp?ID=187
Posted on Apr 07, 2009
asnowman
  • 788 Answers
SOURCE: installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 01, 2009
  • 81 Answers
SOURCE: resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Posted on Nov 19, 2009
Meter stays in tariff 2 but can manually change to tariff 1
I really tried to help you from the video you sent, but there is no listing on the web fo Lucartronic taxi meter company. Do you have any other information you can give me to help you?
Jan 03, 2013 | GPS
Tip
Diagnosis Electric Hot Water Tank Problems and Repair It
I understand that you electric hot water tank is not producing hot water. To diagnosis the problem we will need a few tools. Here is a list of the tools you will need.
Multi-meter
Screw driver (Flat and Philips)
¼ inch nut driver or ratchet and socket
5/16 inch nut driver or ratchet and socket
Diagnosis Electric Hot water tank problems:
1. First you will need to remove the service panels on the side of the hot water tank to expose the thermostat and heating elements. Careful as power is still on to the unit. Now that you have removed the service panels we need to proceed to the next step.
2. On the thermostat there are two wires coming into the top two screws these are line one and line two they are the main power feed. Take your probes from the multi-meter and touch to each screw and you should receive a reading of 220 volts. If you receive this reading then move to the next step. If you do not get a 220 reading then your breaker is tripped or bad.
3. Got the proper power then you will want to check the thermostat reset button. In the middle of the thermostat is a red button press it in and see if it clicks. If the button clicks it means that the thermostat has tripped do to over heating. Wait an hour and see how your hot water is doing. If still the same replace the thermostat.
4. Use your multi meter to check for power to the heating elements. The heating elements have two screws with wires on them. You will want to take one probe to each screw and see what the VAC reading is (if power is present you should receive 220 volts) if you do not get the correct reading then the thermostat needs replaced. You will need to do the same thing to the lower element.
5. To check the heating elements turn off the power to the unit at the breaker. Check to make sure the power is off by using your meter at the thermostat. Remove the wires off of the element and check it for continuity if not continuity then the element is bad and needs replaced.
Replacing the Thermostat
1. Turn off the power.
2. Label and remove all wires from the thermostat
3. Pull clips forward on sides and pull thermostat upward to remove
4. Install new thermostat in reverse
Replacing the Element(s)
1. Turn off power to the unit
2. Turn off water to hot water tank and drain
3. Remove element from tank
4. Slide new element in tank
5. Turn water supply on and check for leaks
6. Reconnect wires
7. Turn on hot water faucet some where in the house to allow air to escape from tank.
8. Turn power on once hot water tank is full.
Thank you for choosing FixYa.Com
Justin
on May 08, 2011 | Plumbing
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
The 'boost' button on my aqualisa digital shower won't switch off. It comes on when I press the shower on (without actually pressing the boost button) and when I press the boost button to try...
Good Morning drlesleyanne. The issue you describe will down to the PCB inside the push button controller. If this does not send the correct signal to the processor box it can cause the unit to 'fail safe' and this is why the unit needs a power reboot. The remedy to this is to replace the push button control itself and once installed should allow the shower to work correctly again. All our digital products have five year guarantees, so you can always call our Customer Service line on 01959 560010 and they will replace this for free.
Kind Regards,
The Aqualisa Team
Jul 29, 2011 | Home
Whirlpool Duet Dryer is stuck on "Control Lock" and no other controls will work. This happened when plumber had to move it to install new hot water heater. Please help! Thank you
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control and to eliminate the possibility of an electronic glitch if pressing and holding the End of Cycle button does not work. Replace the control if unplugging and the pressing the End of Cycle button fails to unlock it.
Nov 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Basement was flooded when washer inlet hose burst. Approx 6 in of water in the area where the water heater stands. Complaint of no hot water, no pilot flame. Attempt to light pilot successful but pilot...
Certain Rheem water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts.
White Rodgers Intelli-Vent PowerVent Control Equipped Models
  1. Step 1 Turn the water heater's blower switch off and disconnect the power cord for the water heater (refer to your particular model's operation guide for the exact location of the blower switch). Disconnect the Molex connector attached to the bottom of the control pad (the left most connector with five pins).
  2. Step 2 Turn on your multi-meter and set it to read resistance or "ohms". Connect one of the multi-meter's probes to the number two pin and the other probe to the number three pin of the Molex connector (middle black wires). If the reading on your multi-meter reads below 9k or above 45k ohms, the flammable vapor sensor is faulty and in need of replacement; you cannot reset the system until this issue is resolved.
  3. Step 3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful
Oct 01, 2010 | Rheem Water Heaters
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Sep 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
No hot water. Circuit breaker not the problem. Which plate do I open to check the eco?
Remove access panels on water heater's side the top thermostat has a red reset button on it.
Press reset button and it will take about 30 mins or more to get hot water. If you have a meter or test light check wires to elements for power.
This would be the first thing to check on the water heater.
May 21, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
I have recently had 2 new immersion elements fitted to my hot water, when we switch the boost button the water starts to heat up then after a couple of minutes the electric supply drips out?? Can you...
It sounds like your breaker is too small (amp rating not high enough). You need to check the wire size going to and from your breaker to see if you can put a higher amp rating breaker in. It would be advisable to have an electrician check it out.
Nov 15, 2009 | Carrier TSTATHCP Programmable Thermostat...
Water heater problem (no leak on floor)
shut off the power to the hot water heater wait 5 to 15 min. If the noise stops it is the water heater eating up electricity. Turn it back on if noise starts again feel about 5 or so feet down the hot water line. If this line is hot you have a leak beyond the hot water heater. If you still hear it when the power is off to the water heater. next turn the water off on the cold water line at the water heater with the power off also Look at the water meter and see if the hand or wheel on the meter is moving and it should no be. Also think if the breaker to the hot water is off the electric meter should practically stop if no refrig oe anything else on. Have someone watch the electric meter and switch 1 breaker at a time leaving the one you just shut off in the off position until you cut them all off. Should the meter still be moving you have a main service cable shorting somewhere call the power company to advise you further if this is the problem.. Should just cutting the circuit breaker for the hot water heater stop the noise and down the hot water line is not hot then you are probably wasting power due to a thermostat or element inside the hot water heater.. Thank you j
Nov 23, 2008 | Ruud Central System Air Conditioner
Computers & Internet Logo
554 people viewed this question
David Payne
David Payne
