Question about Hotpoint HSS25GFP Side by Side Refrigerator
It is warm inside - Hotpoint HSS25GFP Side by Side Refrigerator
  • Hotpoint Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 22, 2010
Why tracker transmission lock in cold weather?
You have valves inside the transmission and electronic controls inside the transmission. When cold, valves do not work because the fluid is too thick. Once warm the fluid thins out and allows tranny to shift OK. You can burn your tranny up by not letting it warm up.
Feb 18, 2013 | 2002 Chevrolet Tracker
I have an 1994 ford escourt wagon LX..i have replaced the thermostat and housing back flushed the whole system threw heater core..the air still doesnt blow hot enough air to warm the car up inside..this...
Does the air coming out of the vents change when you move the temperature control knob? If you can't feel it, you should be able to hear the change
Feb 13, 2011 | 1994 Ford Escort
I have an 1994 ford escourt wagon LX...i have replaced the thermostat and housing and back flushed the whole system..the air still doesnt blow hot enough air to warm the car up inside..this needs to be...
Even though you already flushed it I will bet the heater core has build up in it. My escort did that and i had to hook a garden hose direct to the heater core and flush it with dawn dish soap both directions several times untill all the slimy old antifreeze inside it finally broke loose and came out. Then it worked great
Feb 09, 2011 | 1994 Ford Escort
I have an 03 passat wagon that when it dips below 50 degrees inside the car it will not start no click no nothing but i can put a heater inside and warm the inside up and it will crank fine any thoughts
Have your ignition switch replaced, the solder connections are probably loose, the wiring expands somewhat when warmed and then it makes the connection.
Jan 06, 2010 | 2003 Volkswagen Passat
Inside wall warm
Possibly the Mullion heater which keeps the door gasket from freezeing when the door is shut and humidity is high.
Oct 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Smeg fridge, light on but warm inside, thermostat?
hello my frd...this a commonly seen prb...dont worry!!!this happens bcoz there is a prb in THERMOSTAT...thats y its warm inside...thermostat s the one wch takes care of u r fridge...the best way to solve this prb s u better call u r company engineer for reparing the fridge...if u r fridge s within the warranty period...u dont want to pay him even a single penny..or else u hav to pay his service charges
Jul 24, 2009 | Refrigerators
Inside Microwave is Hot
Hi, What you noticed is perfectly normal...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Feb 26, 2009 | Hotpoint RVM1435 Microwave Oven
2002 ford taurus wont give heat inside.
what temprature did you get on temprature gauge ? When you say the heater core , i think on the heater register som are under the dash . The water flow are controled with a tap , when you have the control on warm the heated water flow , when the control on cold , the tap is closed and now water flow. It can bee the wired to the tap som are loose . You must look up under the dash and se if you see the wire.
The are 2 hoses tho the heater , and they go inside from the engine in to the heater. Look for the hose , you find them inside the engine rom and they go inside the car.
If you start the car and run it warm , then you put the heater control on warm. Then you try to feal if the hose som go to the heater are warm, if only one are warm the fault are the tap. And then you must look under the dashboard and lokate the tap.
Hoope this tips could help you
Dec 01, 2008 | 2002 Ford Taurus
Frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
42 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
