Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
No Internet access. Wep personal Connects to router fine Router diagnostics says dynamic or static ip set incorrectly but dynamic is set for auto assigning ip
    President:
  • 1,768 Answers
1. You possibly may have the IP address statically assigned in the NIC card properties and or the router. ???
2. Go to the control panel then to network then check the properties of the TCP/IP procol properties to see if you have it set to "obtain an ip automatically"
also see if you have " DNS to obtain automaticall".
3.Unplug the ethernet cord for about 30 seconds the connect it back to the ethernet port.
4. check to see if you have a connection to the internect.
5. call your ISP to see if you line has had any disconnects or maintenance.
6. check the router status ( this will tell you if you have disconnected from the ISP 's server and need a possible reset .
7. Do a ipconfig /all to see if you have the "media disconnect" error > this is done by going to the command prompt and typing "cmd" enter then you DOS prompt will show.
8. check you status lights on the router to give this information to the tech when calling your ISP to walk you through a reset or check the connection on the DSL/ CABLE line.
I hope this helps. Have a great day!ormation to the tech when calling your ISP to walk you through a reset or check the connection on the DSL/ CABLE line.
Posted on Aug 22, 2010
What is the IP address for my Firestick?
The IP address of an item, unless you specifically assign it one, is done automatically by the router when it connects to the network. This address can be different each time the device connects depending upon what other devices are already connected.
Jan 02, 2016 | Computers & Internet
No internet access
Disable all the firewalls on your computer, ensure that the wireless card on computer is on and is working fine. ensure you entered the right network key.
Oct 04, 2008 | NetGear RangeMax WPN824 Wireless Router...
I'm using two Macintosh Computers. I followed the quick setup wizard, all the right lights are lit. I've reset my broadband modem, I've reset the Dynex Router. Yet I can't make contact...
Richard have you tried setting up static ip addresses on the MACs
If you have other p.c's on network with auto ip assignment then alter the DHCP server lease to 192.168.1.10 to 192.168.1.240
then make ip address static 192.168.1.241 subnet mask 255.255.255.0 default gateway 192.168.1.1 and on the other mac
make ip address static 192.168.1.242 subnet mask 255.255.255.0 default gateway 192.168.1.1
http://www.macinstruct.com/node/550
Jul 07, 2017 | Dynex DX-E402 Router
IPad drops internet connection
Your best bet is to go into Settings and then reset your network settings. If that doesn't work, reset your router. IF neither of those work, reinstall/ugrade the latest firmware of your ipad.
May 04, 2011 | Computers & Internet
We set up secure and then could not get back into it. Do we use Dynamic or Static? WEP or WPA?
For that access your router and enable DHCP in router then save settings and restart router. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 02, 2010 | NetGear WGT624 Wireless Router
I have no internet connection with the router but can surf without the router and only my modem
You need to configure your router WAN settings as your internet service provider.
If your ISP gives you static ip then configure it as static.
If ISP gives user name and password to connect inteernet then configure router as pppoe.
http://192.168.0.1
or
http://192.168.1.1
Click on wireless settings enable wireless then WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.If you are able to see password in * or # then you need o add new password but if you are able to read it then note down it then you can connect with it.
If you are not able to access router with above ip and user password then press RESET button for 10 seconds it is in back side of router.
Then you can access it with above method.
Jun 13, 2010 | NetGear WGR614 Wireless Router
F5D7231-4 stopped connecting to Internet via downstream router
Why did you change it from dynamic to static? My suggestion would be to put it back to dynamic and let it grab a good ip address from the gateway. The other option is to contact whoever managed the network at your apartment and see what they will charge you for a static IP address.
May 23, 2009 | Belkin (F5D7231-4) Wireless Router
Netgear error says cable unplugged
Is this a static ip or a dynamic ip, if its a dynamic ip make sure to have dhcp enabled on your router
Apr 12, 2009 | NetGear WGR614 Wireless Router
Unable to connect ipod touch to home network
Sounds like an I.P. problem. If set to "Dynamic", try "Static" IP. Had a similar problem with my Linksys wireless camera. It worked...than it didn't. Sounds eerily similar.
Mike
Feb 16, 2009 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Please Help! My IP is driving me crazy!
modem only transmits signal.
router talks to your provider and gets IP address from them, depending on your subscription, you may have a static or dynamic IP.
your computer gets internal (home network) IP from the router, you don't have to worry about that since it is the router's IP address that is seen on the internet (router splits / shares a single internet connection in home networks).
about wireless connection from computers/wi-fi gadgets to the router, must configure the router with the ff:
wireless network name (aka SSID)
security type (WPA/WEP) and password/passphrase/security key
channel (1-12)
the above info must be then set to the connecting computers/gadgets
about wired connection: a working ethernet cable (looks like a phone cord but fatter) and a working computer/gadget ethernet port.
Wii will work - check Wii's website for connectivity options / instructions.
Dec 18, 2008 | NetGear WGR614 Router
Computers & Internet Logo
141 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
