I have a kenmore dryer model # 417.84052500. I dried 2 loads of laundry just fine, but on the third load, the dryer kept shutting off mid cycle, the lights on the front of the machine would flash and when I opened the dryer door it did not appear to be warm inside. Any ideas what might need to be fixed?
ginko
  • 19396 Answers
SOURCE: door won't open Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door sensor/ lock is not working well
Posted on Mar 21, 2008
  • 1028 Answers
SOURCE: kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Posted on Jun 02, 2008
  • 240 Answers
SOURCE: F22 code appears on Kenmore Elite Front Load washing-?
communication error between control board and panel. Make sure both are replaced together. common problem
Posted on Jun 03, 2008
Master_Tech
  • 770 Answers
SOURCE: HOW DO YOU TAKE THE DRYER OFF?
If it is stack from the factory (ie..came as one peice) you cant
Posted on Jul 26, 2008
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
Model 110-8866293 shuts off mid cycle . Heat is fine.
Clean your sensor strips. They may have junk on them from dryer sheets that displace moisture. If no wetness is sensed the dryer will assume them clothes is dry and shut down.
Sep 14, 2012 | Kenmore Dryers
Hi, my dryer is shutting off in the middle of the drying cycle. It will sometimes go back on and sometimes not. It is still heating up when it is running. If you would give me an indication of...
it may be the thermofuse, which is a safety feature. You can bypass it. I believe to have someone work on it would be under a $100 if that is the problem. I do not know how often this happens but I am assuming that it happens every time you try to do a load of laundry. If this is true then I would take the fuse out tape the wires together and watch the dryer complete a load of laundry. I would then buy a new fuse which are under $30. The fuse is a safety feature which will keep the dryer from catch fire as it shuts it down if it gets to hot. Hope this helped tim
Sep 25, 2010 | Kenmore Dryers
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
Jul 14, 2010 | Samsung DV337 Electric Dryer
Kenmore 120V portable dryer only gets lukewarm
Sometimes the venting in the dryer needs ton be cleaned out as it plugs up and the high limit thermostat makes it short cycle on the heat cycle.
Mar 20, 2010 | Kenmore 82722 Electric Portable Dryer
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
Kenmore drier model 110.96591440 will not cut off in either drying cycle
DO YOU MEAN IT WON'T SHUT OFF? DOES THE TIMER ADVANCE? IF IT STAYS IN THE SAME PLACE, AND YOU ARE ON AN "AUTO DRY" CYCLE, THE TIMER WON'T ADVANCE IF THERE IS A RESTRICTION IN THE EXHAUST.
DISCONNECT THE DRYER EXHAUST FROM THE BACK OF THE DRYER AND TRY ONE LOAD OF LAUNDRY. IF IT WORKS O.K., THERE IS A PROBLEM WITH YOUR DRYER DUCT WORK. HAVE IT CLEANED OUT AND TRY IT AGAIN.
Apr 06, 2008 | Dryers
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
