Question about Kohler Plumbing
When hot water is turned on the pipes make this vibrating sound. i have two sinks in my bathroom. When I turn the hot water on on sink 2 the pipes vibrate. Sink 1 is fine.
  • Kohler Master
  • 43,501 Answers
There is a loose washer in the faucet...this flaps as the water goes through it and makes the vibration...
You either need to replace the faucet or the cartridge (washer) in the faucet that valves the water...
This will stop that vibration and hammering sound
heatman101
Posted on Aug 22, 2010
Hot water pipe clinging when closing valve
This could be a lot of possible fixes. Try putting a piece of tube insulation around the pipe at where it is hitting on a another pipe or something. This would at least stop the noise. That is the nature of the beast with the noise. Hot water responds that way depending on what is going on in the air .
Jan 02, 2013 | Home
I have a rinnai R53 natural gas tankless water heater. we are having a very difficult time finding someone who knows how to work on these. Our problems include: having to rely on turning on one trusty...
The issue is the flow sensor, if the faucets are restricted (like showers heads) then there is not enough flow to trip the sensor. This could also be related to pipe size and water pressure.
Mar 31, 2017 | Rinnai Desa Vent-Free Infrared Gas Heater:...
I have 2 bathrooms with a common wall. We hear a constant low tap of the pipes in the wall between the bathrooms. We have checked toilets, sinks, faucets, etc for leaks. Sounds as if there is pressure or...
You have water hammer effect it is caused by a fast closing valve,it can be solved by installing a water hammer arestor in the plumbing line or maybe the water pressure is too high and a pressure reducing valve can be installed in the main water line.(the pipes in the wall are not secured properly that's why they vibrate)
May 19, 2011 | Plumbing
I have two vanities and a shower in the bathroom. We only get hot water to the sinks when we turn on the shower to hot. Even if we turn off the shower we will still get hot water for a while. It just seems...
Check the water supply lines to the shower at the faucet handles. If the fitting for the hot water line connected to the handle is loose, it can twist and kink off the water supply further down the line when you turn the faucet handle. I'm not exactly sure how this could be relevant otherwise, but under normal design circumstances this type of scenario with your shower wouldn't matter for other faucets.
May 01, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
Very low pressure when turn on the hot water faucet in sink
Shut off the water supply and open your faucets, and apply air pressure (min. 30psi) to dislodge any blockage in the pipes.
Oct 23, 2009 | Plumbing
Leak from bathroom sink behind the wall
hello , usually there will be water supply lines coming in from behind the wall area and if it isnt leaking at the supply valve it self then you may need to open up the wall area behind the sink and find out what is leaking it depends on what type of pipe is used most likely you have cooper tubing and sometimes these tubes after a while may leak or form small holes or it may be a leak at a soldered joint remeber there are 2 lines one for hot one for cold and you can turn the off by shuting off your water at the main valve then repair the leaking area.
Oct 10, 2009 | Belle Foret Bathroom Sink Faucet -...
Vibrating dishwasher pipes
a plumber needs to install a anti knock pipe at the valve under the sink ....this should stop the vibes ...should only cost about 50 -75 bucks ...depending on the per hour rate of the plumber
Jul 26, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Clunking noise in sink
You are describing a problem known as water hammer. This will ultimately cause damage somewhere in your plumbing system so it should be addressed. If you are handy you can install an air chamber near the sink. If you want more information let me know. good luck.
Jan 17, 2009 | Home
Plumbing Logo
357 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
