Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
We emptied all of the ice out of our fridge and now after leaving the ice maker handle to the 'make ice" position, nothng is happening
  • Frigidaire Master
  • 43,501 Answers
I would try flipping that handle up and down a few more times...
but here is a tip that will give some other things to try also..
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Aug 22, 2010
Ice maker stuck on crushed ice instead of cubes
most likely you have ice built up in the door or icemaker that has frozen hard easiest thing is to turn of fridge empty freezer leave door open to melt the ice remember to empty ice maker wash it out removing all ice ect. then when all is dry and clean start it up and see if that doesn't fix it.
Aug 20, 2014 | Kenmore Refrigerators
I just emptied all the ice out of my ice bin to take on a picnic, but now my ice maker won't make more ice. I have had it for 5 years with no problems. What happened? Did some setting get bumped? or...
1. Check to make sure the when you removed the ice bin that you did not leave the lever by the ice tray in the up position. That is the one the stops the making of ice whe the bin is full. This is the only easy solution.
2. Check to make sure that the vent between the freezer side and produce bin is closed. This is used when opened to keep that bin colder than the rest of the fridge. If that isn't it then there a few easy solutions.
Jul 02, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Water not going to ice maker
That happened to me once and while it was with an older fridge, it's possible it could be the same problem. In my case, the water inside the supply line actually froze. Tried using hot towels and such on the water supply line but in the end, I had to empty out the Fridge and defrost it for a day. Water for the ice maker worked again after that... and I had a clean fridge!
Hope this helps...
Mike
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice-maker in my Daewoo Fridge Freezer (FRS-U20DAI) is not working. The ice tray does not empty.
is there ice in ice maker but it wont empty?
the ice maker has built in heater underneath. thats how the ice detaches itself from the ice maker and the fingers rotate them out.. if you have ice in the ice maker then replace ice maker
hope this was helpful
Mar 27, 2010 | Freezers
Removed ice maker drawer and replaced it, but now
The bar is down?! ;) There is no feeler arm on the "ice in the door" fridges... Check if the switch on the right from the icemaker is in "on" position. If it is:
  1. Remove ice bucket from the door, and re-seat it. If it sits high - you'll have no ice. If this did not help:
  2. remove grille on the bottom of your fridge, and find the testing procedures sheet for the icemaker tucked inside that grille.
Nov 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water running from bottom front of refridgertor
Can you tell if there is any water in the ice cube "basket"? If it is full, then your ice maker is not sensing the water level "full" and keeps running. The fridge is normally able to handle a little overflow, about one pint or so, but cannot handle a constant run of water. If it is empty, the supply line may be disconnected somehwhere along its route, most likely near the bottom and at the rear of the fridge. You can pull the fridge out and look at it by removing the back cover. If the line is disconnected, reconnect and have a happy new year. If it is connected, here are two options as I see it.
One - check to make sure your ice maker is properly plugged in and installed at its location in the freezer. If you or someone you love has recently cleaned the fridge or shoved a fifty pound turkey in there, the ice maker may have come dislodged.
Two - replace the icemaker. These units come as a single purchase as you cannot just buy the senser. Cost of most of these I have seen are about $125 for the part (easy to install), which can be a deal breaker. Ice cube trays are $1.99 for two at the local hardware and they don't usually overflow.
Dec 26, 2008 | Refrigerators
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Apr 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
189 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
