Question about Garmin GPS
When I turn on the gps it only stays on for maybe 5 seconds. When I plug the gps device in it will start up but when I get to the initial screen with the warning about not typing in info while driving and you have to hit continue or ok nothing happens. It is frozen there. Also when plugged in it will no longer turn off. The device was working perfectly. Nothing happened to it. I have always stored it safely.
  • kclements80 Aug 22, 2010
    My Garmin 255W will not stay on longer then 5 seconds. When it is plugged in the car it will not move past the warning screen. It is only 8 months old. THis problem happened out of the blue no damage.
    Thank you this worked perfectly. I really appreciate it.
    Genius:
  • 1,478 Answers
I suggest you reset your GPS, to reset your gps, follow this steps, turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the Garmin GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 – 30 minutes in order for it to requires fix to GPS satellites. with this, this should fix the problem.
Take care.
Posted on Aug 22, 2010
You will need to update the Garmin GPS using there "webupdater" Click on the link below to get started
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
When you turn the unit on a message comes onto the screen that says. UNIT CURRENTLY CONTAINS NO MAP! INITIATING MAP UPLOAD. you cant do anything with the unit message stays on the screen.
when you turn the unit on a message comes onto the screen that says:
May 01, 2011 | Magellan eXplorist 400 GPS Receiver
Can not see the maps, stuck at home screen
If you had just started the device, you may have to wait a minute or so for the software (programs) to load, initialize, etc. before you start getting the user screens. Just make sure you are plugged in, or the battery is not low. When the programs start and after the GPS (satellite) signals are located, you'll be able to see your current location, etc. (and start using the device).
Jan 02, 2011 | Tomtom ONE XL GPS
When I turn it on, it stays on the 'thinking clock' and wont start any further than that. At one point I got a message that said, "Error: Initialization Error." So I cant do anything with it. It wont start...
You have corrupt software in the internal system. Solution: Seek a repair center like the Jungle Ghost at http://www.jungleghost.com/repair_service.shtml and they will repair it. If the unit is in warranty .. return to Magellan
Oct 18, 2010 | Magellan Triton 400 Handheld GPS Receiver
Wont Start
use the reset button usually located on the bottom, sometimes whan the battery is naff it will also do that
May 14, 2010 | Tomtom XL 330S GPS Receiver
Why does my GPS system have a difficult time locating satellites?It says ''acquiring satellites'' for about 5 minutes. Then it says it can't locate satellites. Should it continue trying? Why does it do...
this is what my navigon says about gettting the gps to connect.
Initializing the GPS receiver
In the upper right-hand corner of the display, the GPS symbol appears. As soon as
data from at least 3 satellites is received, the symbol changes to (GPS Ready). Note: If possible, position the device with a clear line of sight to the sky to successfully
receive messages from the GPS satellites.
Note: GPS initialization requires data from at least three satellites. If GPS data is not
available, the receiver will not initialize.
Note: It can take up to 20 minutes to initialize the integrated GPS receiver for the first
time.
Note: Each time you turn on the device, GPS receiver initialization begins. When GPS
data is available, reception starts within one minute.
If the navigation device has been switched to standby for more than a week, the next initialization
can take up to 10 minutes.
Jun 19, 2009 | Garmin GPS
My magellan maestro 3100 won't stay powered on
If the battery is fully charged then press the RESET button.
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Powerless Garmin
i think i have the same problem. it shows the boot screen but turns off after about 2 seconds. mine does not work when connected to the USB or AC power either. when i plug it in to the computer, it turns on the boot screen and just stays there. ideas?
May 29, 2008 | Garmin StreetPilot C330 GPS Receiver
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
GPS Logo
358 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
