Question about Pitco Frialator SG14 Deep Fryer
SG-14 backfires when turning on
I have 2 SG-14s and the wire screen at the end of the burners where they hook up to the tank tubes seem to get clogged or burnt looking, causing the fryer to backfire when I turn up the thermostat or turn on the valve quickly. If I take them out and rinse them off, the fryers will start up like new for about a month at max. I even ordered new burners, and that didn't help the problem any further. I'm wondering if this is a design problem and if anyone else has had this same problem. Any suggestions? Thanks, Rick
  • Anonymous Oct 03, 2008
    THIS BACK FIRE EXPLOSION EPISODE IS SO VERY COMMON IN THESE FRYERS,I WORK IN A HOTEL AND WE HAVE ABOUT 8 OF THESE FRYERS,AND EVERY ONCE AND A WHILE THEY ALL COME ACROSS TO THIS PROBLEM.EVERYTHING IS CLEAN NO AIRWAYS ARE CLOGGED THE AMOUNT OF WATER COLUM IS CORRECT AND IT STILL EXPLODES,THE ONLY CURE THAT I HAVE FOUND IS REPLACING THE GAS VALVE AND THE ELECTRONIC MODULE BOX UNDERNEATH THE FRYER.I THINK THE GAS VALVE IS STICKING AND JUST NOT OPENING ALL THE WAY TO GIVE THE BURST OF PRESSURE NEEDED,THE GAS VALVE IS GETTING THE CORRECT VOLTAGE ALSO.IN FACT I AM WORKING ON ONE RIGHT NOW AT WORK I WILL LET YOU KNOW HOW IT TURNS OUT.10-3-2008
I seen this problem over and over again, the best and simplest way to fix if to just clean your burners. Removed one by one and get them clean with hot pressure water. Most of the time, this easy and fast job will resolve the problem, and don't forget, get those burners cleaned every 6 mos. It requires a 1/2 in socket.
Posted on Oct 23, 2008
I blow the tubes out with co2 gas runs much cleaner and better performance
Posted on Oct 28, 2008
I HAVE A FRYER SAME MODEL THAT WHEN IT CALLS TO FIRE IT MAKES A VERY LOUD EXPLOSION SOUND.THE PILOT LITES THE GAS COMES ON AND THEN IT EXPLODES BLOWING OUT THE PILOT,IT WILL DO THIS OVER AND OVER AGAIN.EVERYTHING IS CLEAN.MY THOUGHTS ARE THE GAS VALVE IS NOT OPENING ALL THE WAY TO GIVE THE THRUST OF GAS THAT IT NEEDS.
Posted on Jul 26, 2008
    Champion:
  • 254 Answers
These screens will need cleaned around a 90 day interval It would appear that your problem may be unburned fuel deposits. with a manometer check to verify that the manifold pressures match those on the ID plate. You can either take this reading off the lower side of the gas valve or at the end of the manifold or the center of the manifold depending on your model. After this has been checked you need to check the primary air intakes. you can adjust the air intakes untill you have a blue flame w/white or light blueish looking tips.
Posted on May 31, 2008
Deep fryer catching on fire
From the video it appears many things could be wrong. The baffles and burner tubes could be clogged, the burner itself can be clogged, the flue is blocked, or this unit is using the wrong type of gas, ie: propane on a natural gas fryer.
Recommended steps for troubleshooting.
1. Verify proper gas type. Natural or Propane.
2. Check Burners, tubes, and baffles, clean all soot and debris from them.
3. Check for and remove any obstructions from the flue.
Apr 27, 2013 | Kitchen Appliances - Others
I have a pitco deep fryer... Everything works fine, but when the burners go off, I get a popping sound that blows out my pilot light
It sounds like the burners and tubes may be dirty and clogged in your fryer. The burners are removable and need to be cleaned periodically. The tubes can be cleaned when the burners are out using a burner cleaning brush. If the above mentioned items appear to be clean, you may have a gas pressure issue.
Jan 08, 2013 | Kitchen Appliances - Others
Got a build up of soot want to clean the mechanics/baffels etc got a manual on that
If you have build up of soot you need a service and a gas fitter to do it .
Jun 15, 2012 | Pitco Frialator SG14 Deep Fryer
My Pitco fryer is shooting large flames out of the door. . . . HELP!
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Regards.
Aug 05, 2011 | Pitco Frialator 35C Deep Fryer
The flames on our pitco frialator (40lbs) are not suctioning through the tunnels and is burning an orange flame out the front of the burners instead. We are mobile unit with two 100lb tanks. We clean the...
The flame is restricted to flow inside fire tubes, make sure that all fire tubes are free of soot/ carbon deposit. There should be no air flowing (hood fresh air or any ventilation) or entering the flue box because this will cause the flame to roll back to burners. Also, make sure that the unit receives the right amount of gas pressure as specified in the nameplate, this will surely eliminate carbon build up on fire tubes and burners.
May 27, 2011 | Pitco Frialator SG18S Deep Fryer
What are most common problems found with pitco frialator fryers?
Some of the most common problems with Pitco fryers is failed Hi-Limit thermostats, carbon build up on burner tubes, and dirty or clogged burners. This hi-limit thermostat is mounted inside the fry tank on one of the burners. Often the cappillary tubes are damaged or broken during cleaning causing the limit to fail. The hi-limit is the most common part I replace on Pitco fryers. The other common items are self explanitory. Keep the fryer clean in all areas, including burners and tubes. You will see the repair man less often.
Feb 09, 2011 | Pitco Frialator SG14 Deep Fryer
I have a used sg-14 pitco that i want to use outside for my family reunionsdo i have to use a large tank oflp or can i use a 30-lb tank when i light the pilot it will not stay lit when i release the button...
You can check the voltage generated by thermopile using a voltmeter. Set the voltmeter on milli-volt setting then heat up the thermopile. When properly heated, it can generate 500 to 750 milli-volts.
May 20, 2010 | Pitco Frialator SG14 Deep Fryer
Orfice on fryer tube has flame on it
The things you will want to check and correct are the burner venturi, this is where the gas and air mix (where you see the flame when it backfires), this being dirty or clogged will cause this problem, your burner at the top being dirty can also cause this. Also, be sure the orifice is clean. If possible you should also check the gas pressure and set it accordingly. The other thing to check is the burner tubes themselves, these are the tubes that go through the fryer, many times with this scenario the tubes are getting clogged. These tubes being clogged will not necessarily cause this problem, but you may as well clean them while you are there.
May 09, 2009 | Pitco Frialator SG14 Deep Fryer
Fire from lower ports
is this unit propane?if so the baffles are clogged,you need to remove the burners theres 2 bolts that sit on top of them.loosen the bolts,remove the burners and clean out the baffles.clean the burner orfices as well.this should do the trick.
Dec 25, 2007 | Vulcan EF3 Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
432 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
paulcarew
starztruck4u
Dan Webster
Dan Webster
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
