Question about Kenmore HE2 Plus Front Load Washer
Getting f1 error. did what manual said(tried rinse, spin} stillwont work. will not fill, makes clattering sound.
    President:
  • 1,382 Answers
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Posted on Aug 22, 2010
WHAT IS CAUSING THE BRAKE ASSEMBLY TO CLATTER DURING RINSE CYCLE
THE BREAK ENGAGES OR DISENGAGES, THE CLUTCH AND TRANY IN SPIN CYCLE. ARE U SURE THE CLATTER IS NOT FROM THE MOTOR COUPLER? IS THERE A GOOD TIGHT SPIN? OR LOOSE?
Mar 23, 2015 | Amana Washing Machines
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Sep 25, 2013 | Fisher and Paykel (IWL12)
Machine goes through the wash cycle then stops before it rinses and spins . Machine displays F1 OR F5 which indicates an error has occured , have to empty manually but cant get it to spin at all .....
Hello
F1 is usually a low water code.Check your hoses and water supply inlet screen for any bulid up of dirt or sediment.
Also the water inlet valve may need to be replaced.
F5 is a water temp fault.Possible bad heating element or thermostat.
The F1 code could be causing the F5.
Due to low water.
May 04, 2011 | Indesit Washing Machines
It has an F1 error code. It will start the water flow for about 2 seconds. Stops and beeps f1 on the screen. I hit the stop button and start again and have to repeat this 3 times before the wash machine...
The manufacturer has issued a remedy for the F-1. What you do is empty the machine of water and unplug it. Open the control panel and remove the pressure hose. Blow out the hose to remove sediment . Re secure it to the control and retry. No parts needed. F-1 Error infothemobilian_1223.jpg
Feb 01, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
Rinse and Spin cycle stuck and not rinsing or spinning properly
Just read your posting.Now just a couple of questions.Are you using a warm fill for the wash or cold?if are using warm try cold only and take note of the time it takes to fill.I don't think your cold water is filling properly. My manual says that with only the 1st rinse light working it is your control module that is faulty. Please try a cold water wash and reply back so we can rectify this problem.
Jun 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hotpoint Aquarious WF630 error code H20. It will fill and wash with both hot and cold water but when it gets to rinse and spin the error code flashes. It will however spin if i manually change the...
H20 does in fact indicate a problem with the incoming water supply.
Check the inlet hoses/s to make sure they are not kinked or restricted in anyway, more so when the washer is pushed back.#
Make sure tap/s are fully turned on, make sure you have good water pressure.
It would also be a good idea to check the gauze filters in the inlet to the valve/s.
Feb 08, 2010 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
The machine works fine until it reaches the rinse cycle.
The buzzing sound is the cold water inlet valve is getting power but water is not able to enter. You need to have the valve replaced or make sure the cold water is turned on at the sink. Hope that helps, let me know.
http://tclaundryrepair.com/
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
261 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
