Question about Furuno GP32 GPS Receiver
WAAS I have a F. GP 32 GPS/DGPS unit and have found that dispite what is discribed at P,34 of owners manuel I cannot select in WAAS/DGPS set up any setting other than GPS oppisite mode. I run NObeltec with a ComNav Commander Autopilot. I cannot get the boat to follow the route track. It is usually 50 feet to 100 yds. parallel to the route. Is my GPS setting correct? Perhaps it should be set to WAAS. I also have it set to, after WAAS search, Auto 134; and opposite connection, Data 02 and opposite station, Auto. My question is: Why can't I set it to WAAS? and Where should it be set? Also I have a Furuno 1834C-BB Radar Nav Net VX2. When I have depth displayed, there is no large depth number displayed on the lower right corner, but it does display, in a box on Radar Mode. How do I get it displayed on Depth Mode?
    New Friend:
  • 132 Answers
Sounds like the problem is with the pilot. You may be expecting too much from nav mode you should check the antenna connector on the WAAS issue
on VX2, are you marking a good bottom on the sonar screen, but have no digital overlaid? never seen it, must be a BB thing
Posted on Jan 15, 2010
Garmin GPSMAP 172C - cannot find satellites (WAAS)?
WAAS is a seperate service from GPS. It provides GPS corrections so if you can not get WAAS there is no big problems. you unit just wont be as accurate as normal. WAAS only is for North America and EGNOS for Europe. You may want to turn WAAS off for now. I suggest trying a update for the unit. You will need a memory card and Garmin USB programmer. Then just go to garmins site to get the latest update. If you need a USB programmer feel free to Contact GPSCity.ca or GPSCity.com. They are the leading experts in Garmin GPS.
Jul 12, 2010 | Garmin GPSMAP 172C GPS Receiver
Frequently switches from dgps to gps fix .Why is this?
DGPS only works in areas where there is a DGPS beacon, and they're simply not that commonplace. Unlike orbiting GPS satellites, DGPS beacons are fixed land based devices.
When there's no DGPS beacon, the unit automatically reverts to the regular and slightly less accurate GPS.
May 19, 2010 | Northstar Explorer 550 GPS Receiver
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
Garmin gpsmap 162 turns on, works for about two minutes, then a thin black vertical line comes across screen and screen goes blank with the line remaining. I have to unplug and start over. Same things...
Possible Solution found on google....
My old Garmin 162 chartplotter was mounted on the binnacle guard and served me
well for many years. Lately, it started getting very slow to refresh screens.
At times, it would shut down with only a black vertical line on the screen. On
our last cruise, the screen froze at a very critical moment. Too old to
repair, I bought a new Garmin 440, which I am very disappointed with, but
that's another story.
I read an article in the GoodOldBoat newsletter about the Department of Defense
making changes to the WAAS satellites that have caused problems in Garmin 72
and 76. Garmin's tech support recommended to turn the WAAS function off on
affected units. So I got out my old 162 and turned the WAAS off and it works
fine. To make sure it wasn't a fluke, I turned it off and on several times,
and it always slowed down with WAAS turned on. With it turned off, the
position error or accuracy, increases 1-2ft, not a big deal. I hooked the unit
up on my truck and drove around. Not a problem. Further reading indicates
that other brands of GPS are also having problems with the new WAAS
transmissions.
So if you are having problems with your GPS and it is new enough to have WAAS,
try to turn it off
Sep 28, 2008 | Garmin GPS
Using a DGPS on a 76csx
there is no possibility to use DGPS with 76csx... due to the fact that 76csx receivers use chipset the 'sirf star III' series and this chipsets don't allow use any RTCM data.
regards,
frankie, poland.
Feb 02, 2008 | Garmin GPSMAP 76Cx GPS Receiver
Furuno gps gp 32
The only place to get that screen is through a Furuno authorized dealer. The unit is sealed and gas filled to remain waterproof. You're best bet would be to send the unit in to Furuno for repair. You wont save much doing it yourself because the cost of the screen makes up most of the cost of the repair. They will also make sure that all the software is up to date for the new WAAS satellites that recently went on line.
Have you tried adjusting the contrast? On that model I believe you tap the power key while the unit is on and you will see 2 sliding scales on the screen, one for brightness and one for contrast. Up or down arrows select the scale and left or right arrows adjust it. If the contrast and brightmness aren't tied into the power key on that model, they're somewhere in the set up menu.
If adjusting the contrast doesn't help then the screen has most likely failed. This is commonly caused by old age, however repeated exposure to extreme heat or cold can cause premature failure.
Jan 25, 2008 | Furuno GP31 GPS Receiver
Garmin etrex legend
I had this problem today, updated the software, now the unit seems to be working perfectly. The unit "crashes" (single line down screen center) as soon as it get enough satelites to work with WAAS.
Go to Garmin site for software updates. Download and install the WebUpdater. Once or unit is hooked up to your computer and you have internet access, the software will download and update your GPS with the latest software fixes. I had software Version 3.7. For the Legend, Version 3.9 fixes the problems with WAAS.
Jan 04, 2008 | Garmin eTrex Legend GPS Receiver
My Garmin GPSMAP 76S will no longer accquire any satellites
I had the same problem? GPSmap76S was hung up trying to AutoLocate. It just couldn’t find itself, and it just stopped working all of a sudden one day, while I was traveling. I spoke with Garmin about the problem, and they advised me of an ongoing problem with WAAS. I was told that I should "Disable" WAAS, because the signal from the WAAS satellites had been changed by the government, and Garmin had not yet put out a software update to address the problem, on the 76 units, anyway. Also said that an update "should" come out, in the future, however, no commitment or promise on that. Evidently, once your unit hits one of the WAAS signals, it scrambles up the receiver in the GPS, because mine sure went crazy. The support guy also said, that if this did not correct the problem, I might also want to try a "Master Reset". So here’s what happened.
I disabled WAAS, but this did not correct the problem. The unit was still lost out there somewhere, trying to AutoLocate, so I ended up doing the “Master Reset”. Please read up on this procedure before trying it, and understand that you “will loose” any settings that you might have made to the GPS, along with all waypoints, routes, tracks, etc., however, my maps actually remained in tact? This procedure will actually set the unit back, just as it was when it originally came from the factory. Once completed, you will then have to allow the unit to initialize it's self again, just as you did when the unit was new. If you have forgotten about doing that, it simply means that you need to set the unit outdoors and leave it “on” for a while (15 – 20 minutes), until it actually AutoLocates it’s self, or locks in on your current position. Once this is done, re-do your setting preferences, back to the way you had them before the Master Reset. At the very least, you’ll have to re-set it to the correct time zone, and tell it about daylight savings time. Note: It’s a very good idea to go thru first, and jot down your page settings and main menu settings, before doing this procedure, or the screens may not look familiar to you, once the unit resets. You think you’ll remember them all, but you won’t. But whatever, once you have done the “Reset” and “Initialization”, you must now hook the GPS up to the computer and reload your waypoints, routes, etc, back to the GPS. You did have them saved on your computer, didn’t you? Hope so… If so, you should now be good to go…………….
My unit now works like a champ, good as new, just not as accurate, due to WAAS being turned off. I still don't know if the WAAS issue, was part of the problem or not, but I do know that the Master Reset got the unit back to working immediately, allowing it to locate itself almost instantly. What a relief…………..it’s a little work, but it takes much less time than it took you to read this post…………..
Hey, when all else fails, call Garmin 1-800-800-1020. They are good guys and willing to help, in fact, I would advise you to call them before you do anything, so you can describe to them, exactly what your unit is doing. I am only relating my situation and what happened to me. Your situation may be different……. .
Dec 08, 2007 | Garmin GPSMAP 76 GPS Receiver
ICOM GP-360ML GPS Receiver
I had this problem about a year ago. If all you need is the firmware update they will update it at no charge and they told me if it needs repairs they most likely will not have the parts becaus it is a discontinued model. They also said they did checked it and found no other problems. Sent it in to Icom:
Icom America
2380 116th Ave NE
Bellevue WA 98004
They did the firmware update and sent it back to me free of charge. It works great now and my chart cards work great.
Sep 09, 2007 | ICOM Informatique GP-360ML GPS Receiver
Furuno GP32 GPS Receiver Logo
231 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
