Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
LG model # LDS5811st stops and displays OE. What does that stand for
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Posted on Nov 16, 2010
Error meaasage 0E Drain Error what to do?
This OE error or fault code indicates that the machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Finally, if the drain line is clear and the pump seems to be clear, you may need to replace the drain pump assembly.
Mar 01, 2016 | LG 4681EA2001D Original Water Pump Drain...
How do I replace dishwasher door hinge spring?
http://www.repairclinic.com/PartDetail/b200p9/LG-Dishwasher-Hinge-Spring/4970ED4004D/1337779?modelNumber=LDS5811ST#repairHelpVideoTabs
Oct 07, 2014 | LG Dishwashers
Displaying oe
LG's 'oe' stands for Open (door) Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 25, 2011 | LG WM2301HW Front Load Washer
My LG washer keeps stopping during spin with the display OE.
heatman101
Oct 21, 2010 | LG WM2101H Front Load Washer
I have a LG Dishwasher Model LDS5811ST. The code
Did you find anything out? Mine won't drain either.
May 14, 2010 | Dishwashers
I have a LG diawsher, model # LDS5811ST that is
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
LE means locked motor disassemble the filter and work your way down to the macerator(steel chopper blade) remove it and see if the side labeled "this side up" is really up, its in english... dont think the chinese labourers paid attention to the warning cause i have seen alot that were wrong way
You also should remove the door panel and check for a broken wire (usually the blue one)
If all the wiring checks out - it is most likely a broken or locked up impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | LG Dishwashers
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
OE what does this stand for
oe stands for outlet error possible solutions are : drain hose kinked , filter blocked or the pump impellor is blocked.
Jan 02, 2009 | LG WM-2277HW Front Load Washer
LG dishwasher Model: LDS5811ST getting error code: 0E
OE is a drainage problem...check for twist or obstruction in drain hose .. make sure filter screen is clear... Hope this helps..
Sep 17, 2008 | LG Dishwashers
Lg - LDS5811ST Dishwasher OE Error Code
hi
May 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
296 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
