Question about Lands Phones
Caller ID not working. It did work then one day nothing. Called phone company they checked and said nothing on their end. This is the KXTG5777ST base phone with 4 satellites. None of them have caller ID working.
Try entering *82 then followed by the number u are calling, for example : the number ur whom to call is 123456789 then u'll enter *82123456789 try that and if that works. go to urprovider to have it unblocked coz u have a blocked phone caller id. and note ur phone number will be show if it is emergency call....
glad 2 help...
Posted on May 04, 2008
All of the sudden our called ID stopped working on all of our phones, how can I restore the caller ID?
Check with you telephone service provider to ensure you still have the service. Customer service can help you. Caller ID is provided by the phone company.
Apr 30, 2015 | NorStar M7310 Corded Phone
I recently bought a 82738. Caller ID shows up on the screen as "Unavailable" rather than caller info. I had my former TV, a Mitsu73 inch hooked up the same and caller ID worked fine. Any...
The T.V. caller ID is from your phone provider. The T.V. itself shouldn't have any impact on how the caller ID works. I would call your phone company and see what they say, it sounds like a problem on their end.
May 05, 2011 | Mitsubishi Televison & Video
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
My kx-tg5632 panasonic phone caller id no longer works. we just moved. it worked at the other location, now it doesn't. phone company says it's not on their end...
Before accepting the phone company's word, make sure another basic caller id phone can display CID. If it does then check the programming in the phone's set up menu to be sure it hasn't been mistakenly disabled.
Apr 26, 2010 | Panasonic KX-TG5632 Phone
My panasonic kx-t7636 phone has caller id. however
you need to go to the call settings on phone and adjust the call waiting there ok
Jul 17, 2009 | Panasonic KX-T7636W Corded Phone
Caller ID
First off seven to nine you do not use an external cid unit for norstar systems. Make sure you have a caller id card in the main ksu or key service unit( the phone cabinet) It should say CI on it. If the card says DS then you do not have a caller id card on the system and will need to exchange it for one. Then the system phones will have to be programmed for cid.
Feb 16, 2008 | NorStar Meridian M7310 Phone
CALLER ID-CANNOT SET IT
there really shouldn't be anything to set up. if you have another caller id box or phone, try plugging that in to the phone jack first checking for dial tone, then the caller id. if neither are working, call your phone company. if only the caller id is still not working, ask your phone company if it is activated.
hope this helps.
wg
Feb 12, 2008 | Panasonic KX-TG1033S Cordless Phone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Cant get the talking caller Id
I lost the talking caller id after a thunderstorm. Can you tell me how to program it? I don't have a maual.
thank you.
Jan 13, 2008 | Sakar HT-848CL Corded Phone
Caller ID not working in India
In USA, CANADA, telephone company uses FSK for Caller ID detection while Indian Telecom companies uses DTMF standard. this is the mismatch and reason for caller ID not working.
u need to purchase seperate caller ID for it.
Oct 28, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
Lands Phones Logo
479 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
