Removing Stand from LCD Monitor
I just new to know how to remove the stand from a Star Logic 19" monitor so that I cam place it back in the shipping box.
  • 558 Answers
Remove the obvious screws that hold the stand you can see that from the rear of the monitor stand
Posted on May 10, 2008
Hi, same here, trying to remove stand from Flatron W2361V, no visible screw :( and not sure where to pop open because the bottom is pressure sensitive and acts as a power up button
Posted on Aug 08, 2010
I need to detach the stand of HP 1950 TFT monitor screen and then mounth the monitor on a special stand. How can detach the monitor from the hinge seen below the screen.
Removing the base is covered in the manual. You can download a copy from HP here.
If you don't like clicking a link the full URL is
http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=3463255&targetPage=http%3A%2F%2Fbizsupport2.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc01446658%2Fc01446658.pdf
If I have helped you, please take a moment to rate this solution. Thanks for asking here!
Mar 18, 2009 | HP w19 19" LCD Monitor
Pedestal fixes screen tipped forward. Is there any adjustment to fix screen tipped slightly back?
most screens are on a pivitable base stand.if it falls forward or back open or remove the cover from the base stand connected to the back of the monitor and tighten the nuts at the sides.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
HP L1940 19" LCD Monitor
Hi...there,
It's open from the front bezel of the screen.. Place a piece of cloth or fiber cloth over the screen and carefully lifted up the bezel... do the same from other angles...
Dec 16, 2008 | HP L1940 19" LCD Monitor
Disassemble anlg lcd 19''
The following link will show you the 'pdf file' for the assembly of your monitor.
You should be able to reverse this procedure in order to disassemble it in order to put it back into the box.
http://us.lge.com/download/product/file/1000000449/L1951S-BN.PDF
Go to page 4 and look for "Removing the stand base" to see how to disassemble. Binary Bob
Nov 29, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
19 inch star logic monitor
bad vga board however you can open it up and see if the capactors are blown replacing them may solve this problem however when an LCD monitor goes white typically it is the microchip that has gone bad so I sell the monitor for parts and buy a new one.
Aug 18, 2008 | Star Logic 17" LCD Monitor
Position of monitor
There is no mechanism on the stand to raise or lower the monitor.
Aside from removing the stand an setting the monitor on the table leaning against something or machining a shorter stand, there is no way of lowering the e196fp display
May 31, 2008 | Dell E196FP 19" LCD Monitor
Star Logic 17 in LCD Monitor
May be your video in the computer that trouble you.
Try changing the video card and see the result.If it is still the same that mean your video card in the LCD is the problem.
Apr 19, 2008 | Star Logic 17" LCD Monitor
Need to know how to Disassemble AL1912 19" LCD Monitor
The ones I take apart have a snap on front bezel.
gently pry at the lcd edge with fingers in center left or right to get it to bow , dont damage the lcd with too much pressure.
it will start to separate ,put a plastic knife or such in the outside crack and work your way around once you have one side the rest will be easier. you have to bow the inside edge out(away from the lcd) because of the plastic clips.
luck.
Apr 17, 2008 | Acer AL1912 19" LCD Monitor
Acer AL1916W 19" for wallmounting
remove the both screws at the backside and stand will go unmounted.. now you need two stripes to hang your monitor on the wall.
Jan 24, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
6,026 people viewed this question
David Payne
David Payne
