Question about Philips 50P8341 50" Rear Projection Television
FLUID CHANGE NEED TO KNOW HOW TO CHANGE THE FLUID TUBES ON A 50 INCH PHILIPHS MODEL 50P8341 THANKS FOR THE HELP
  • Philips Master
  • 8,617 Answers
Http://www.tv-forums.com/forum/TV_Equipment_C4/Projection_TV_Forum_F24/Changing_CRT_Coolant_P15302
Posted on May 04, 2008
I need to change the flyback of my TV Philips of rear projection model 50P8341. I do not Know how to remove the damage flyback. First, I tried to remove the anodes that are connected to each of the three...
Leave the CRT's alone!!!!! You will ruin them. The red wires come out of the Fly-back. Pull the rubber caps up and then with a twisting motion pull each red wire out 1 at a time.
Apr 27, 2011 | Philips 50P8341 50" Rear Projection...
Colors on my TV seem to be washed out. Convergence is adjusted OK, brightness/color/tint settings don't seem to make a difference. I seem to have bright halos around all light colored images.
The fluid in the picture tubes needs replaced. It is a job for a professional. It usually costs about $250.00 for the job. You might say it's like giving your set an oil change.
Apr 09, 2011 | Philips 50P8341 50" Rear Projection...
Help i need the factory color settings form my Philips 50P8341 50 in. TV
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2011 | Philips 50P8341 50" Rear Projection...
I have a PTV916 Model # 60P8341A. I cleaned the lenses and the mirror inside the TV however, I can see alot of dust inside the actual lens. Is it possible to clean the inside of the lenses?
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
CRT Fluid is Cloudy
69189a5.pngSOLUTION
Jan 13, 2011 | Philips 50P8341 50" Rear Projection...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
How would you replace the coolant for a philips 50p8341 50 in rear projection television
you have to remove the picture tube, drain the fluis through the drain plug, then take the lens cap off, clean out all the crud, then fill it up with new fluid, don't try to do it while it's still in the set, you could spill fluid on the board and cuse major damage, also, if you remove the tube, usually you will need to re-adjust the convergence of the tubes, usually only the blue and green tubes need this, pretty major repair, i don't recommencd doing it yourself, but getting a qualified repairman to do it.
Sep 08, 2009 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50 in. Rear... Problem:
you need to change the coolant in the CRTs ( picture Tubes) and the set will get its color and clarity back.
Jul 07, 2008 | Philips 50P8341 50" Rear Projection...
Philips 55p8342 chassis ptv916
To get a new remote call a local TV service company or you can order directly from the manufacture. The cloudiness of your colors are caused by possibility of two things or both: 1) The mirror and lenses inside your TV need cleaning (use window cleaner & soft cloth) spray liquid onto cloth, 2) The fluid in picture tubes need to replaced. To replace fluid (ethylene glycol) take tubes out of unit, drain fluid, clean fluid chamber, add new fluid. How you can tell if fluid is cloudy? Take off screen assembly look into each light (red, green, blue) the picture should be clear. The red tube, light, is normally okay, so use as referance.
Feb 16, 2008 | Philips 50P8341 50" Rear Projection...
Phillips model 50p8341 titanium-finished 50-inch Red tint to picture
Your Red CRT may be on its way out. Try turning down the G2 screen control on the red CRT just a little. That should help for now. A new red tube wil be a reality in the future.
Jan 21, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
