Question about Eureka Whirlwind LiteSpeed 5843 Upright Vacuum
The bristles aren't rotating. Is there an easy solution to this?
  • 694 Answers
The belt probably broke. Simply purchase another belt and replace. These belts are made for much stress, and if you've had the vacuum for even a month, they can easily break.
It may also have slipped off the motor shaft, causing the brush to spin freely.
Posted on Aug 22, 2010
Rotator Professional. Half-moon shaped piece of rubber fell off while cleaning bristles. Where does it belong?
Mounts on a C-shaped plastic divider that is in the top cover. It looks like it helps hold the motor steady...
Oct 04, 2015 | Shark Vacuums
Why does my brush turn?
Most likely the belt that connects the motor to the brush has broken and needs to be replaced. A relatively easy fix.
Nov 12, 2014 | Shark 12-Volt Cordless Hand Vac
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
I have a Hoover Steam Vacuum, All Terrain, and the bristle brushes are not rotating. They appear to be seated properly and, the entire vacuum is clean and free of lint, hair etc., so everything is working...
I checked the owner's manual and the parts breakdown for your model F5807. Both showed that your model has a stationary brush strip and not rotating brushes. Is F5807 the correct model number?
May 18, 2010 | Hoover F5807 SteamVac Wet/Dry Vacuum
Front brissels dont rotate
have you removed the bristle bar to see if carpet fibers have wrapped around the ends causing the bar to bind up, have you noticed any smoke smell, if so your belt may have broken, easy way to check, flip the unit over and remove the bottom cover plate, whats wrong should be obvious at that point.
Dec 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The brush/bristles won't rotate
Probably a broken drive belt, fairly cheap and really easy to fix, remove sole plate cover to access belt, 5 minute job.
Jun 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
DCo7 too much suction hard to push
This suggests that the bristles on your brush roller are worn out.  When the bristles are a good working length, rotation of the roller actually helps to pull the machine over the carpet. When the bristles wear down this effect is lost.
May 20, 2009 | Dyson DC07 All Floors Bagless Upright...
Eureka Whirlwind LiteSpeed 5843 Upright Vacuum Logo
119 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
