Question about Olympus Mju 750 Digital Camera
My Olympus u 750's telescopic zoom is jammed in the extended position. The cause seems to be the last segment of the zoom, containing the lens, which is not properly aligned with the other retractable zoom segments. I don't remember knocking the camera - not sure how this happened. Is this a common problem that can be fixed by gently forcing the crooked segment back into it proper place? Or if it has to be sent for repair, is it worth the trouble and cost?
  • Olympus Master
  • 5,412 Answers
Only you can decide if it worth the cost of repair - check on replacement cost first
Posted on Jun 15, 2017
3 Suggested Answers
  • 2985 Answers
SOURCE: Zoom lens Motor Problem?
The suggests the zoom control failure
Only Olympus can fix it to it will have to go back.
Posted on Nov 08, 2007
  • 3587 Answers
SOURCE: Olympus Camedia C-740 Focus Problems
check batteries please?
Posted on Mar 16, 2008
I have dropped my friends camera (while it was on). It hit telescope first and got jammed is there anything I can do? It is an olympus stylus 760 7.1 All-Weather. It was purchased on ebay about 6 months...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2009 | Olympus Stylus 760 Digital Camera
I dropped my olympus 540 zoom camera and lens cover is jammed
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 18, 2009 | Olympus SP-350 Digital Camera
1) Make sure that the batteries are in good condition
2) Check and clean any dirt or corrosion from the battery terminals.
If the power supply voltage suddenly drops during initialization,
or when the lens is trying to extend itself, it could produce this
kind of error.
3) Make sure that the lens extension tubes are not mechanically
4) Remove the batteries, turn the unit ON and wait for it to fully
discharge any internal capacitors, then put the batteries back
and try to turn the unit back on. This should fully RESET the
internal CPU.
Generally this kind of error means that the camera's internal
computer is trying to activate the lens zooming motors, but
the motors fail to move as expected.
Other causes could be:
a) burned out ZOOM motors
b) burned out motor drive circuitry
c) bad motor positioning sensor
d) defective computer components
e) failed internal firm-ware.
none of these cause are user fixable.
Hope this helps
Nov 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
Canon Powershot S50 -lens extends and then retracts
There is a common problem with the A series Powershots, that the lens assembly jams in the telescoping zoom, or in the digital imaging module, in which the lens assembly has to be replaced. I'm not sure if the S series has these issues. You can check with Canon support to find out.
Aug 08, 2008 | Canon PowerShot S50 Digital Camera
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Lens jammed
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 04, 2007 | Canon PowerShot A520 Digital Camera
Problem in Olympus FE-170 Digital Camera
Aug 13, 2007 | Olympus FE-170 Digital Camera
Zoom error message
Aug 07, 2007 | Olympus SP-350 Digital Camera
Olympus C-3000 Zoom telescoping lens problem
The small gears that link the viewfinder and lens may be out of sync. If you are a technical person, you can remove the frontcover, first taking off the topcover, (one screw is hidden under the mode dial). Power up the camera and remove the batteries when the lens is fully extended. BE CAREFUL NOT TO TOUCH THE CAPACITOR! Gently lift the viewfinder and move the viewfinder gear one tooth. It will probably only move one way. Put the batteries back in and try the lens. If this does not solve the problem, you may need to replace the lens or viewfinder.
Mar 20, 2007 | Olympus C-3000 Zoom Digital Camera
Olympus Mju 750 Digital Camera Logo
69 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
