Question about Marantz SR-6200 Receiver
I bought a marantz sr 6200 and in surrond get static out my right front y???
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
  • 4 Answers
SOURCE: Marantz 6200
Your unit's micro IC, is in need of a reset.Un-plug the unit and locate the semi large yellow capactor on the main board. (r-h side facing front) Now flip the unit over and look thru the vent holes in that same area and locate the two solder pins. Short them out with a thin metal object, like a straightened out paper clip or wire, and turn it over (just discharge the cap and remove your wire) this will default all settings and restore normal operation.
Posted on May 27, 2009
  • 256 Answers
SOURCE: Marantz sr 6200 he/she only has Audio in the way 7.1
Edson I think we know each other. Are you in Miami? You have two beautiful daughters... How are they? So, you have a Marantz, which is the 2nd company I worked in Long Island, NY when I was in the Hi Fi business. In order that we give you the best service, may I suggest that you repeat your request and ask for someone in audio. I am in the repair of computers mother boards etc. If you are still in Miami here is my telephone number 786-234-0692. Mi nome e Constantinos (arzconst is my inetrnal nickname with Fixya.com). Tudo es o Prtugu?s que falo. Mi espa?ol est? mucho mejor. Gracias de su consideraci?n y opci?n de nuestro servicio...
Posted on Jun 19, 2009
dunnbiker
  • 8546 Answers
SOURCE: marantz receiver SR-5000:
Swap the speakers with each other to isolate the speaker from the wire and the amp. What fails now? Isolate accordingly.
Posted on Jan 21, 2010
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
My Marantz SR6200 is not playing loud and it only plays in analog and when it does and I select tuner cd or Dvd will play, there is also a little crackling on the front right speaker. please if anyone...
Hi, maybe you have speakers misconnected or speakers wiring with short circuit (joined bare cables), please check them because if this continues for a long time, your device could get damaged.
Oct 20, 2013 | Marantz SR-6200 Receiver
No surround modes produce any sound . only have sound on s direct mode. marantz sr 5200
Not having the ability to look at it on the bench, more than likely your DSP chip is bad. If you have a local repair house that is willing to confirm that is the problem without charging you an arm and a leg, that's your best bet. It is an expensive repair, anywhere between 300 to 500. At that point, I would say to replace the unit. Sorry for the bad news, but that's my "best guess" The only other thing to check would be your "Audio input Settings" Make sure it's either on "Auto" or whichever type you are using. "Digital Coaxial", "Optical", or "Analog" (RCA) hope this helps! If you have any further questions, just post a reply and I can help further. Best of luck!
Jun 03, 2010 | Marantz SR-5200 Receiver
Jun 19, 2009 | Marantz SR-6200 Receiver
Marantz 6200
Dec 03, 2007 | Marantz SR-6200 Receiver
Loss of volume on left channel
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Oct 15, 2007 | Marantz SR-5200 Receiver
No output from left channel after crackling sound
Jul 08, 2007 | Marantz SR-4200 Receiver
Marantz SR-6200 Receiver Logo
59 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
