Hi. I have windows XP 2007. Each day, when I first log on, a message says: "Virtual memory too low. Windows is increasing memory on your paging files." This takes an hour. If I reboot during the same day, I have no problem getting online. Is there a fix for this? Thanks, Ginnie
  • 20 Answers
Google "virtual memory too low solution." Trusted sources are PC Magazine, Microsoft...
(In my case, I ran "msconfig", go to "Start up" tab and uncheck programs I did not want Windows to load at boot. That would free up memory.).
Posted on Aug 22, 2010
I get a message low memory how can i fix this dell inspiron 1525
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
Jul 21, 2010 | Dell Inspiron 1525 Notebook
Tip
Solution to Virtual Memory Too Low Problem
This problem was reported by one of our readers that in spite of having a sufficient amount of RAM, he is running out of Virtual Memory and his Windows PC gives the following error:
Your system is low on virtual memory. To ensure that Windows runs properly, increase the size of your virtual memory paging file. For more information, see Help.
This is a common problem and you may have seen it if you are trying to open many heavy applications at the same time like Microsoft Office.
Let’s see what the causes are and what can be done at this stage.
Windows XP or Vista uses the concept of Virtual Memory that aims at providing the additional memory from the Hard Disk if most of the RAM of the computer is already occupied. This memory used from the Hard Disks is called Paging File. Windows reserve some part of the memory for this purpose only (this is one of the reasons why we see less memory than specified on the hard disk).
Virtual Memory also known as Page File or Swap File can be located at C:\pagefile.sys (it is system hidden and can be viewed if you Uncheck the option of “Hide Protected Operating System Files” inside Folder Options).
on Nov 17, 2008 | Microsoft Windows XP Professional With...
Windows XP Virtual Memory is low. How can I regain memory?
Virtual memory is "memory" on your hard drive, not actual memory. The best way to regain this is reboot and shut down some of the stuff that runs automatically when you DO boot up.
(This Virtual memory is space set aside on your hard drive that the processor moves data into and out of like it would put data on a memory module ... but in comparing the two, the virtual memory is SLOW.)
You can increase the size of your virtual memory to anything you want. Some say too large a allocation will slow you down and too little will cause crashing or slow opertion. You are 99.44% probably set to let Windows manage your virtual memory (default) at this time.
thanks for posting your question to FixYa.com
positive comments are welcome
a
Nov 02, 2009 | Gateway Essential 500 PC Desktop
I get a "virtual memory is low" error message. How do I correct
You have two different & independent problems. I will solve them one by one.
First of all, for increasing VIRTUAL MEMORY you should Right Click on "MY COMPUTER" then choose "Properties", then goto "Advanced" tab and then in "Performance" frame click "Settings" and then again goto "Advanced" tab and there you will see a "Virtual Memory" frame and then click on "Set" and increase the size of your virtual memory.
Second problem is due to installing many instances of XP. You can re-format your whole drive again and you will enjoy a fresh & single copy of XP again.
if you finds any difficulty or any doubt is there then feel free to contact me again.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Jun 29, 2009 | Dell Inspiron 1300 Notebook
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Virtual Memory Minimum Too Low
Hi!
Here's the procedure on how to increase virtual memory of your PC:
Right click on My Computer > left click on Properties > Advanced > Settings > Advanced. Under Virtual memory left click on Change.
Select (left click) on the Drive on wich Windows XP is installed. In most cases this will be Drive C.
Under Drive:
Space available: Select the radio button labeled: Custom size:
To play it safe, in both the Initial (MB)size: and Maximun size: dialogue boxes type 2560 (i.e. allocate 2.5GB for the pagefile) provided you have the free memory space to spare. If you don't have enough free memory available enter the amount of memory you can spare, and meanwhile seriously consider getting a larger Hard Drive.
Mine is set to 4096MB (4GB), max. allowed by XP. This may seem like quite a lot, but the reason for this is that recent games now require a lot more real and virtual memory to function correctly, even if you have 2GB of RAM. Having a larger pagefile size does not hurt performance as such; it only takes up a bit of additional disk space.
After setting the new page file size left click on
OK > OK > OK. Then restart the computer.
Dec 21, 2008 | Microsoft Windows XP Professional With...
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
RAM memory and Adobe Photoshop 7
The solution is to increase your virtual memory size...
Considering Win XP SP2 system.. the following procedure may be used to increase ur virtual memory / page file size...
Right click 'My Computer' --> Properties --> 'Advanced' Tab --> 'Performance' Settings --> 'Advanced' Tab --> 'Virtual Memory' Change --> Type in a custom size of 1024MB or something like that (not too much) --> Press 'Set' --> Close the windows --> restart -->DONE!!!
I hope that this solves your problem
Bye
Have a nice day
May 11, 2008 | Adobe Photoshop 7.0 for PC
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
