Question about HP Pavilion DV6775US 15.4" Entertainment Laptop PC Notebook
I opened my computer and it was on, but the screen was frozen so I shut it down and tried to reboot it, but it wouldn't turn on. I thought it was something to do with the battery being dead, so I plugged it in. The light right next to the power outlet on my computer turned on, but the light that usually turns on when its charging did not turn on. I took out the battery and put it back in, and tried holding down the power button, but nothing works. Whatls wrong?
  • 942 Answers
It has something to do with the power supply of your unit or the motherboard itself, especially when you isolate the battery and plug only the power cable and i wont turn on. In this case, you can reseat the power supply by removing the cables and battery when the unit is off, remove the screws below it, remove the hard drive, remove the optical drive then remove the power supply and reseat it. Then perform the steps in descending order (insert optical, hard drive, screws, battery, cables). Turn it on and observe if there are lights lit on the keyboard. If you don't know how to do this or if symptom persists, consult HP tech support for repair of your laptop..
Posted on Aug 22, 2010
Kindle fire hd is frozen. Was trying to exit out of Silk. Will not shut-down/power off. Has been at 82% power since this afternoon. Tried plugging in to charge - still will not shut-down.
Soft Reset:
  1. Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
  2. Your reboot screen should appear when you release the power switch.
  3. Give your device time to reboot for a minute or two.
  4. Turn the Kindle Fire HD back on
Nov 28, 2016 | Tablets & eReaders
Tip
Computer common problems easy fix.
The most common problem with computers is them freezing up.
When applications dont load or freeze up.
The easiest way to fix most problems is usually just the simple act of "rebooting" the computer.
Most of us already know that.
but just in case you dont heres how.
when the computer seems frozen and you seem to have waited longer for it to unfreeze than it takes for bread to toast.. you can try the following.
press and hold the crtl anf alt buttons and double tap the del button.
on older computers using windows 98- 2000 and millenium editions it will usually reboot the computer. also works with older versions.
with xp and vista you will usually fet a differernt screen that will allow you to choose various options.. choose restart.
another way is to click on the start button located on the bottom left of your screen and choose restart option. if the computer is so frozen that nothing works you can press and hold the power button unti lthe computer shuts down.. wait 30 seconds and turn the computer back on..if that doesnt work then you may have to turn of the power switch..but only if you have to..with laptops you will have to take out the battery. when the comp reboots the computer should be unfrozen..if not you will need more help ..just ask us..
on Feb 01, 2010 | Computers & Internet
How to reboot an iPad, a video clip is stuck on running
Rebooting is easy. It is called a hard reboot. Just hold both buttons down until you see a red slider, and then slide it to shut down. It will restart, and you will see the Apple logo.
Oct 30, 2014 | Apple iPad 64 GB WiFi
What do I do when my phone is "frozen" and fails to open?
You can try rebooting. Hold the button at the top of the phone down until you get the "SLIDE TO POWET OFF" option. Once you slide to turn it off and it shuts off hold the same button down down until you get the apple logo. Let it boot back on. These phones are like computers it's a good idea for you to reboot them regularly
Nov 02, 2013 | Apple iPhone Cell Phones
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Shut down, black screen
It may be. Were you enabled hybernation for closing lid, this situation wouldn't have arises. You closed the while on means heat transmission may have caused this situation.
Apr 13, 2017 | Dell XPS M1530 Laptop
The computer keep shutting down.... i had taken down and he feel the mother board or something had been shorten circut.. i had it for 3 years... other than that seem that everything is fine but shut down...
If there was a short circuit it wouldn't power on period. If it shuts down completely and not rebooting your most likely teleconferencing one of the following
  • Power supply is crapping out (less likely)
  • Your computer is overheating (Most likely)
If it is rebooting then your most likely experiencing a software crash perhaps due to a failing hardrive or just general operating system corruption.
If your computer stays up for more than a few minutes try downloading speedfan (click the words "Speedfan 4.4" not the giant button (thats an ad) http://www.almico.com/sfdownload.php Run it and it will display your core and CPU temps anything over 60-65 is pretty **** high, shutdowns will usually occur higher than 75 C though. If you know how to enter BIOS (usually F10) while the system is first booting up, some BIOS will allow you to set a shutoff threshold.
After thought... failing CPU fans can also cause a computer to shutdown.
Comment back with your finding or if you need further help.
Aug 12, 2011 | Computers & Internet
My amazon kindle screen is frozen on the right hand upper corner. The rest of the screen is still fine and works but that corner is frozen.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Jan 02, 2011 | Amazon Kindle 2
Just bought a new LG Axis smart phone today and after loading some applications from the application market on the phone, whenever I went to view an application I kept getting an error message that the...
A Hard Reset might help. it will bring lost file/folders back.
Also to turn on phone in safe mode, but not if cannot get passed initial Android screen.
Pull Battery to power off phone.
Hold Up Volume button, and power on button simultaneously until green android guy and DOS window open.
If Home key is solid button, then also hold
up vollume button, home button, power button.
use volume up and down to scroll.
Scroll down to Reset Manufacure Settings.
Use power button to select OKay.
Then select reboot system.
Mar 27, 2017 | Cell Phones
How can i reboot my acer desktop
try CONTROL+ALT+DEL
select Shut Down
then Turn Off or Restart
*if your computer is malfunctioning or corrupt or frozen.
Theres alway the manual shut down way
HOLD POWER BUTTTON FOR AT LEAST 6 to 10 seconds or until computer shuts down. Then turn on computer and try again.
Sep 13, 2008 | Acer Computers & Internet
HP Pavilion DV6775US 15.4" Entertainment Laptop PC Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
